Author Topic: Machine polishing  (Read 2133 times)
Offline Black9
  • -Given: 35
Machine polishing
« on: December 21, 2012, 04:42:38 pm »
Hi guys looking for some info...
Want to have both my Golfs detailed and can't justify spending £300+ to have them both done so,
Looking to buy a machine polisher over the festive period and a few products to help me along the way...
First off I'm a novice and have never used a polisher in my life so would want a fairly basic one which is easy to use, any recommendations? I know there's a DA type polisher, any other ones out there?
I have a karcher washer, meguiars clay kit and various wax's both in gel and spray types.. What sort of polish should I be going for?
Will also be buying a snow foam extension for my karcher washer and snow foam mixture. Which one is well priced?
Re: Machine polishing
« Reply #1 on: December 21, 2012, 07:28:03 pm »
Multiple similar threads very recently so if you have a look down the page, you'll find a few suggestions.
Polisher - d/a or rotary. Former is easier to get to grips with and unlikely to cause damage. Get one with sample polishes and some pads as a kit. Snowfoam lances - the proper ones are made by the same company but sold by different people. I got mine from elite car care.
Offline paulk
« Reply #2 on: December 21, 2012, 07:43:41 pm »
if you buy a d/a megs 300 and megs microfibre pads are a must for vag paint
« Reply #3 on: December 22, 2012, 07:40:22 am »
With the amount of paint they remove, I'd also get a paint depth gauge if that's the route you plan to go down. I also had to buy four large and four small pads because the pads wore out very quickly.
Offline Black9
  • -Given: 35
« Reply #4 on: December 22, 2012, 09:59:16 pm »
I've had a look on clean your car and the DAS 6 PRO seems like a good machine but I'm not sure which package to go for... I was thinking the SONUS kit as it comes with all the pads and polishes/sealants I'd need to give the car a full detail. Opinions?
Any recommendations on a snow foam attachment for a Karcher washer
« Reply #5 on: December 22, 2012, 11:38:36 pm »
Any of them look good. I'd personally go for Sonus pads and Menzerna polish.
They also do a snowfoam lance which is fine.
Offline plex
  • Awesome Rabbit !
« Reply #6 on: December 23, 2012, 03:58:23 pm »
Menzerna are perfect for Vag paints :)
Offline al-tdi170
« Reply #7 on: December 26, 2012, 11:04:22 pm »
Get a das6 pro
Zaino z pc fusion
Hex logic pads
Good starter!!
Scholl polishes/compounds are quality.
Offline paulk
« Reply #8 on: December 26, 2012, 11:21:25 pm »
hex pads did nothing on my R
Offline al-tdi170
« Reply #9 on: December 27, 2012, 12:17:08 am »
Never heard that before??
They're the best I've used. I've tried everything.
Did you use a correct polish/pad combination ???
Try a more abrasive compound or firmer pad.
« Last Edit: December 27, 2012, 12:18:59 am by al-tdi170 »
