Author Topic: Knocking noise still there and driving me mad  (Read 13462 times)
Offline Black9
  • -Given: 35
« on: December 22, 2012, 05:56:26 pm »
So I have a knocking noise coming from the front left corner of my eddy. Only happens over cobbled roads and bumps on the road.
In the past 2 weeks I've replaced,
Bilstein B12 kit with new OEM top mounts and bearings
OEM lower ball joints
OEM ARB front drop links
Front subframe bolts and spacer mod
And it's still there  :fighting: :fighting: :fighting:
Have no idea what else to replace and to make matters worse I'm hearing a squeaking noise from the rear left of the car over speed bumps too. Not sure if its an interior squeak or something else.
Someone please shed some light  :signLOL:
Offline 56OctyVRS
  • -Receive: 72
Re: Knocking noise still there and driving me mad
« Reply #1 on: December 22, 2012, 06:06:17 pm »
Have you checked the front arb brackets as they can break.
Offline Black9
  • -Given: 35
« Reply #2 on: December 22, 2012, 06:07:44 pm »
No I haven't, can they be checked on a jack or do I need a ramp?
Offline Statller-Stevo
« Reply #3 on: December 23, 2012, 10:38:18 am »
If not Could be the steering rack itself, try to get it on a ramp and bash the tie rods directly from underneath if it knocks the racks fuxxed  :happy2:
Offline paulk
« Reply #4 on: December 23, 2012, 10:44:10 am »
have you checked the arb bushes , i had the exhaust bracket snap on my gti worth checking
Offline Black9
  • -Given: 35
« Reply #5 on: December 23, 2012, 10:59:40 am »
The cars been aligned on Monday so I'll have the guy take a look over it. How much does a steering rack cost in parts & how common Is it to fail?
Offline Black9
  • -Given: 35
« Reply #6 on: December 23, 2012, 03:17:06 pm »
Car was on ramp today. Everything seems solid. When the cars parked and I turn the steering right to left I can feel some play in the rack (I think) and a knocking noise too so it sounds like the rack :sad1:
Also when accelerating with WOT to high-ish speeds I can feel vibration through the wheel. Does this sounds like the symptoms of a failed rack and how much does a new rack from VW cost?
Offline 56OctyVRS
  • -Receive: 72
« Reply #7 on: December 23, 2012, 03:49:09 pm »
Is there any play in the wheel bearings?
Offline Black9
  • -Given: 35
« Reply #8 on: December 23, 2012, 04:14:53 pm »
Don't think so. Will be handing the car into a VW specialist after the new year and have them give it a FULL check over. Bit of a gutter as I've spent a fair amount of ££ already and it's still the same.
Doubt a wheel bearing would cause knocking tho?
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: December 23, 2012, 05:01:58 pm »
Could just be the steering arms rather than the rack itself.
Follow AKS tuning on Facebook
Offline Black9
  • -Given: 35
« Reply #10 on: December 23, 2012, 07:18:57 pm »
Shame there isn't any specialists off the forum nearby (Edinburgh). Anyone know about a garage called autohaus in Edinburgh?
« Reply #11 on: December 23, 2012, 09:33:41 pm »
Could be Al, but when you crack the tie rods from underneath the rack makes a noise from the middle not the ends
I've done loads now
Go on most other forums and you'll see, it's really common with lowered cars
Just a thought anyways
Offline peter
« Reply #12 on: December 23, 2012, 10:55:20 pm »
I've done loads now
Stevo I've got the same problem mate on my eddy, how much would it be supply and fit a new rack  :drinking:
« Last Edit: December 23, 2012, 10:57:04 pm by peter »
ED30, Custom stage 1 remap,  THS FR3 engine mounts, Helix clutch, AP coilovers, W.A.L.K, Powerfex lower front control arm bushes, Heko wind deflectors
Offline Teo10
« Reply #13 on: January 23, 2013, 12:00:07 pm »
Not sure if this will help but get it to Autohaus if you haven't already. Have taken my car there for years and could not reccomend them highly enough. Really decent guys that know their stuff and will get it sorted in the easiest way possible! Use proper VW parts etc and don't take the p*ss out of you in getting things worked on that don't need worked on!
Offline Llew
  • -Given: 45
« Reply #14 on: January 23, 2013, 08:06:06 pm »
Check your wishbone
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
