Author Topic: What boost are you running at stg2+  (Read 3168 times)
Offline donovan2123
« on: December 23, 2012, 07:53:27 am »
As above really. Just wanting to see what boost everyone is running.
I have seen some cars I.e revo at 1.5bar and hold that mid range also seen some at 1.2 bar.
When I try a 1.5bar map i get error sometimes which is lower boost limit somthing.
Re: What boost are you running at stg2+
« Reply #1 on: December 23, 2012, 08:50:18 am »
I've had Revo and GIAC on my car and both run around 1.5 bar. You may see actual values over this at peak spike around 3500rpm, but not held values.
  • -Receive: 453
« Reply #2 on: December 23, 2012, 08:59:46 am »
What turbo are you using?
Offline Shorty
  • -Receive: 25
« Reply #3 on: December 23, 2012, 09:00:48 am »
Bespoke map on mine, peaks 1.7 bar and holds 1.5 bar.
| Mk7 R |
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: December 23, 2012, 09:31:19 am »
I'm not really running 2+ exactly, but currently hitting 1.9 bar peak that tails off to 1.5 at 7k now. It's a Revo race file with a hybrid K04.
Follow AKS tuning on Facebook
Offline donovan2123
« Reply #5 on: December 23, 2012, 10:02:00 am »
Mine ko3 hitting 1.5bar and hold from around 2200 - 2200- 5000rpm
Offline donovan2123
« Reply #6 on: December 23, 2012, 10:04:33 am »
However I have another map which runs around 1.3bar just trying to see what you other ko3 guys are getting.
I mean at 1.5bar I sometimes get a po299 fault code I have changed my dv to both d and g and no difference however I have heard the seals around hoses to intercooler can leak some boost.
Offline pitsirikas
  • -Given: 19
« Reply #7 on: December 23, 2012, 10:41:40 am »
Revo Stage 2+.
Peaks at 1.8 bar and holds 1.3 bar.
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
Offline DANBOY66
  • -Given: 41
« Reply #8 on: November 15, 2015, 08:00:08 am »
this is an old thread i know  :ashamed:
what are people running now days any change since 2012 ?
i have been told i am running 1.85 bar  :happy2:
Dan..
Offline PM30S
  • Edition 30 Revo Stage 2+
« Reply #9 on: November 15, 2015, 02:12:53 pm »
Mine runs Revo peaks at 1.7 and holds 1.4 bar
Offline jacobrownoly
« Reply #10 on: November 15, 2015, 06:32:44 pm »
Revo stage 2+ on my ko3 peaks at 23psi on B9. That's probably too much for a ko3.
Thoughts??
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #11 on: November 15, 2015, 06:51:07 pm »
Mine peaks off the clock, maxes out the standard map sensor using B9. Handles it fine
