Author Topic: Precautions to take when once Re-mapped?  (Read 6281 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« on: July 04, 2009, 01:03:50 pm »
Guys,
Once you have re-mapped a Mkv GTi, other than thrashing the hell out of the car and using the map to it's full extent all the time (which most of us probably don't do), are there any other precautions that you should take to minimise problems or damage to the main components on the car;
I.e. ?
  • Should the cambelt be replaced more regularly, i.e. 40k instead of every 60k/4 years?
  • Should you replace the turbo or perhaps increase servicing in relation to it, so you minimize risk of it blowing?
  • Does the clutch need to be replaced more regularly, or is it highly recommended to upgrade to a racing clutch/R32 clutch?
  • Do the brakes need to be upgraded to cope with the increase in energy and obviously speed?
  • Is a bigger intercooler/further engine cooling definitely required, or is it not necessarily required?
  • Do fuel pumps and oil filters have to be changed?
I'm talking in relation to specifically a bluefin map really, or a revo map of similar power (stage2 iirc?), I'm not aiming for more than 240bhp which will be more than enough. All the other components will remain standard but I want to make sure I'm not opening the car up to all sorts of obvious mechanical issues, so it would be nice to work to prevent these.
Thanks,
Pete.
Pete
Offline TomB
Re: Precautions to take when once Re-mapped?
« Reply #1 on: July 04, 2009, 01:27:51 pm »
Pete,
Personally, I'd change the service to Time & Distance (every year or 10k) and upgrade the brakes before remapping.  I've got R32 brakes (345mm) waiting to go on mine, Leon Cupra and S3 brakes are the same.  They also fit under 17s if you've got them!
I always try to do my cambelt every 40k, but thats because older VW 2.0 16vs threw off their belts at 45k.
Intercoolers and fuel pumps can be changed when you get bored of the power, and I'd leave the rest alone until it breaks.
Oh and I'd get a rolling road test done on it before you start throwing power at it.  I found out mine was 50bhp down, so I want those problems fixed first before they cause me other issues.
« Last Edit: July 04, 2009, 01:32:47 pm by TomB »
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline chungster
« Reply #2 on: July 04, 2009, 01:39:20 pm »
i've said it many times before, the clutch in the std GTI is a weak point if your car has already had a hard life.
i would budget for one incase the OEM item starts slipping post remap.
« Reply #3 on: July 05, 2009, 08:07:28 pm »
Just be on guard and not be stopped by the boys in blue for speeding...   :smiley:
Offline keith
« Reply #4 on: July 05, 2009, 10:13:20 pm »
If your only looking at going to 240 then the standard brakes maybe fine as the ed30 with 230 standard is equiped with the same brakes and they would do but as prev said r32 set up is the best value and worth while. If you are hard on your car then things will go its that simple its the same modifing then wringing its neck things will go.
but be warned once you start there aint no going back :surprised: it all mod mod mod :chicken:
Offline TomB
« Reply #5 on: July 06, 2009, 07:23:19 pm »
Keith, have you uprated your pads and discs?
I've found my OE 312s absolutely awful, and my GTI's about 50bhp down.
I once missed a turning at 40 as the brakes just faded and felt like they weren't working.  I used to have 4 pots, but I started braking much earlier!
Tom
Offline keith
« Reply #6 on: July 06, 2009, 09:09:23 pm »
[/quote
I keep meaning to but haven't. can never find the 345mm r32 ones on some websites.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #7 on: December 13, 2009, 03:09:05 pm »
I won't be running anything more than a Revo stage 2 (the 255ps map) and an ITG panel filter.
The rest of the car will be performance standard with Monza II reps.
What disc/pads would be a good upgrade with that power in mind?
Thanks.
Pete
Offline jcp
  • Just stooging around and finding things out!
« Reply #8 on: December 13, 2009, 03:30:43 pm »
Go for the AP kit much lighter and much more powerul than the 312's- A bigger real world performance mod than 40 hp!
Looking for the bright side of life.
« Reply #9 on: December 13, 2009, 10:38:29 pm »
Since being remapped I oil change every 10k miles and new plugs and air filter clean every 20k miles. Otherwise I follow the VW recommended regime.
Enjoy!
« Reply #10 on: December 14, 2009, 09:33:35 am »
Fuel pump cam follower is something to keep an eye on. (Check every oil change or few thousand miles)  I believe they have been revised with a harder coating though
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
Pete
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #12 on: October 19, 2010, 11:15:53 pm »
You should really be changing your oil and filter every 5k miles!  The 10k miles is really only for 'standard' performance VAG motors.
« Reply #13 on: October 22, 2010, 08:39:25 am »
....Oh  :surprised:  - I thought that 20k mile intervals was for 'standard' motors.
Offline QD MBE
  • -Receive: 102
« Reply #14 on: October 22, 2010, 08:51:48 am »
My Ed 30 although Standard, enjoyed oil changes every 5k, it costs less than £50, so a no brainer to me.
Did it with all my other cars, so no change with this one.
The Roc R has enjoyed an oil change already too!
