Author Topic: Spluttering gti under load SOLVED.  (Read 20926 times)
Offline rich golf gti mk5
« on: April 20, 2013, 08:23:49 pm »
Hi all had nothing but problems from day 1 n now I've had car for about 5 week. Right were do I start 1 st of all I replaced dv and that increased my power by loads as it was completely knackered then cam follower then a coil pack then maf sensor then my live wire goin to maf was dead so got that fixed now when u put your foot down it will splutter or misfire then take off until next gear then same again. If you give it a bit of welly for a min or 2 it will cut power and go into limp mode turn engine off then it's ok til u put foot down again. Take maf sensor out no spluttering but still goes into limp mode. I've reset engine Managment n no codes are back on even tho problems still persist. Really need this fixing any advice.
« Last Edit: April 21, 2013, 02:19:37 pm by rich golf gti mk5 »
Saintsteve
Re: Spluttering gti under load
« Reply #1 on: April 20, 2013, 08:25:54 pm »
You have VCDS.. I suggest you Copy up your fault codes. :happy2:
Then peeps might be able to help you better. :happy2:
Are you remapped? Does the car do this in Stock mode?
If no codes are showing, it could well be a mechanical issue or spark plugs as this wouldn't show up in VCDS errors either.
« Last Edit: April 20, 2013, 08:29:38 pm by Saintsteve »
« Reply #2 on: April 20, 2013, 08:30:08 pm »
Ok will do. How do I do this sorry I'm a newbie thanks
Saintsteve
« Reply #3 on: April 20, 2013, 08:30:44 pm »
Copy and paste is the easiest method ..
« Reply #4 on: April 20, 2013, 08:32:43 pm »
No not mapped I don't think how do I find out. Can u do it with vagcom. I have use of vag.
« Reply #5 on: April 20, 2013, 08:41:10 pm »
Mechanical such as ? I thought about changing plugs as a precaution my car also smells of petrol abit wen cold from start up does any1 else's?
Saintsteve
« Reply #6 on: April 20, 2013, 09:35:43 pm »
Car shouldn't smell of fuel.. They run rich on start up, so you might smell it via exhaust from cold.. As long as your oil isn a wash with fuel! You could log the MAF reading which will give u approx Hp output by multiplying the readings by by 0.80.
Have you checked the PCV valve?
Offline john87
  • -Receive: 53
« Reply #7 on: April 20, 2013, 09:36:23 pm »
it will be your plugs (which you should replace if they've not been done in the last 10k miles) or, failing that, a dodgy coil pack (replace). I've had the problem twice (misfire when accelerating) first time it was plugs, second time a coil pack  :happy2:
« Reply #8 on: April 20, 2013, 09:46:09 pm »
been done on service book 5k agojust replaced 1 coilpack too.trying to upload faults codes now.
Offline john87
  • -Receive: 53
« Reply #9 on: April 20, 2013, 09:54:48 pm »
 :popcornsoda:
« Reply #10 on: April 20, 2013, 09:58:06 pm »
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2173747
   Coding: 040300031C070160
   Shop #: WSC 00187 210 89766
   VCID: 2441A30BE7548338654
« Reply #11 on: April 20, 2013, 09:59:19 pm »
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AD
   Component: GSG DSG         070 0925
   Revision: 04007000    Serial number: 00000504260321
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 214FAA1FF84696100E2
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40890F9B130CBF1861C
1 Fault Found:
01309 - Power Steering Control Module (J500)
            008 - Implausible Signal - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70E99F5B632C6F98D1C
2 Faults Found:
00756 - Left Vent Temp Sensor (G150)
            010 - Open or Short to Plus
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001834378
   Coding: E68D8F2700041800001400001400000000097F075C
   Shop #: WSC 00558 210 00001
   VCID: 2B5348378A8A4C40A4E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00558
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00558
10 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
02498 - Left Low Beam Reflector Motor (V294)
02499 - Right Low Beam Reflector Motor (V295)
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
00906 - Horn (H1)
            009 - Open or Short to Ground - Intermittent
02071 - Local Databus
            004 - No Signal/Communication - Intermittent
01321 - Control Module for Airbags (J234)
01320 - Control Module for Climatronic (J255)
02389 - Release Signal Transmission; Position P/N
01520 - Rain and Light Recognition Sensor (G397)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0DMTT2
   Coding: 0012344
   VCID: 377B644746C2F8A0D06
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012122
   VCID: 77FBA447064238A0106
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0024403
   Shop #: WSC 00999 444 64523
   VCID: EED50123F918F968430
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010551901DE
   Coding: 3F0F0340070001
   VCID: 2A5D4D33857055485F8
4 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
01315 - Transmission Control Module
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 0800
   Revision: AB001001    Serial number: VWZ6Z7H7178053
   Coding: 040004000400001200
   Shop #: WSC 00020 790 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2D57462F749E4270BAA
3 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
03138 - Input AUX IN
            011 - Open Circuit - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2310
   Coding: 0000564
   VCID: 3665694341C801A8CB0
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.1   D04 1606
   VCID: 3363505752BA1480ECE
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 18C802487F6D0C0DC85AC65010CC
   Shop #: WSC 12345 785 00200
   VCID: 78F9A77B0B5C37D819C
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
3 Faults Found:
            011 - Open Circuit
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=5622otlect3bdbf3vkp632g9dm&/topic,19740.0.html
« Reply #12 on: April 20, 2013, 10:03:37 pm »
So no fault codes under the 01-ENGINE label?
« Reply #13 on: April 20, 2013, 10:09:35 pm »
nope. do u hae any idea what this points to. sparkplugs coil packs etc
« Reply #14 on: April 20, 2013, 10:11:04 pm »
Well.. bit of an odd one. Usually spark related misfires are logged in the ECU.
