Author Topic: Gas warning lamp  (Read 3258 times)
Offline no golf clubs at all
Gas warning lamp
« on: August 23, 2009, 05:05:35 pm »
Today an exhaust gas warning lamp lit up.
Never had any issues at all.
I read it could be the lambda sensor.... Is this a biggie?
I'm out of warranty.
Quick trip to my local Indy tomorrow for me then.... :sad1:
I guess at least its a hard fault, so they should be able to diagnose the issue quickly.
someone mentioned in a previous post that they had a fuse go related to one of the fans and that fixed it....would anyone know the potential fuse? are these fuses in the engine bay or in the car?
« Last Edit: August 23, 2009, 05:42:51 pm by no golf clubs at all »
  • -Receive: 453
Re: Gas warning lamp
« Reply #1 on: August 23, 2009, 07:33:18 pm »
 Don't suppose you have access to VCDS to do a scan? In any case, changing the sensor should be easy and painless.
« Reply #2 on: August 23, 2009, 08:24:59 pm »
Nope not got any diagnostic tools :-( I'll just head to my local Indy tomorrow can't bear the ritual fleecing by the main stealer.  Also more chance of the smallest part being fixed...rather than the 18 year old trainee trying to fix it by changing the ecu or the coilpacks...
Wish me luck, by the lack of responses here and elsewhere.... I'm more than a little nervous...
« Reply #3 on: August 24, 2009, 11:02:02 am »
Ok a quick trip to the indy, he hooked up vcds and noticed an alarm code there.  Incorrect air mix or something or other....anyhoo.....apparently it can happen for a number of other issues..
He noted the fault, and cleared the condition. We will monitor and book in, the tech reckons whatever it is that it should be a simple fix and not expensive.
Deffo nothing to do with the fans.
I did notice that my air intake top cover was slightly off...wonder if this had something to do with it.  We snapped it back on, though I am not sure if it will stay there.... Will keep ya all posted just in case the same ever happens to you.
  • -Receive: 453
« Reply #4 on: August 24, 2009, 11:51:18 am »
I doubt that the loose intake would be the cause but you never know...
« Reply #5 on: August 24, 2009, 12:58:28 pm »
Yeah I doubt that too really...hopefully a one off...but first sign of probs I'll get onto the tech and we'll get it in and sorted.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: August 24, 2009, 01:13:09 pm »
take the fault code and look it up on
>> HERE <<
should give you some possible reasons .....
Red ED35 5dr DSG
BLOG | BUILD
« Reply #7 on: August 24, 2009, 03:00:15 pm »
thanks jon-o, top class...I will have to get tech to advise what it was now...i didnt note it at the time. thats a great reference.
i would love to have this diagnostic kit...what does it cost?
i take it you need a windows lap top to start with, then the appropriate cable and software. Though i can imagine that you could cause a lot of damage if not used correctly.
  • -Receive: 453
« Reply #8 on: August 24, 2009, 03:07:50 pm »
Yes unfortunately VCDS software is primarily meant for windows though a few have got it to work with Linux. No official Mac compatibility as yet (if ever).
If you use the software just to scan for fault codes then you won't do any damage.
