Author Topic: HELP - Removing Inside Condensation From Your Headlamps??  (Read 3426 times)
Offline Rich
    • Carpet Underlay
« on: August 25, 2009, 12:56:43 pm »
I cant believe it,
I changed my bulbs last week with some from Regal Bulbs (we get the 10% discount here) with the slightly brighter bulbs... and a touch of blue tint to them.
Yesterday, is the pouring rain, i get back to find BOTH my headlamps have condensation in... the right headlamp worser than the other.
I will post pictures tonight as im at work now.
Please please please how do you get rid of it ? :scared: :scared: :scared:
Offline NotNormal
Re: HELP - Removing Inside Condensation From Your Headlamps??
« Reply #1 on: August 25, 2009, 01:04:29 pm »
Try removing the rubber covers on the back, then running the headlamps on dipped beam
you might need to repeat the several time to dry out the healights units - once condensation free - replace rubber cover on the rear
Don't judge me by your ability !
__________________________________
Current daily crapper - Audi A6 Avant 3.0tdi SLine Quattro
Previous favourite rides :
BMW E92 335d M/Sport (351/520)
BMW  E92 335d SE (339/500)
Golf MK5 GT170 Diesel Sport (220/330)
Audi S4 (B6) - Noggy blue (366bhp)
Evo VI (6 ;) ) RSII - Scotia White (420bhp)
Astravan Sportive 1.9 CDTi - 190bhp
Astra GTE (MK2) Turbo (
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #2 on: August 25, 2009, 01:06:46 pm »
If it happened after you have changed the bulbs, then im guessing you havnt put the rubber bungs back in it propably.  :smiley:
Offline Rich
    • Carpet Underlay
« Reply #3 on: August 25, 2009, 01:09:11 pm »
Should i do this when the engine is cold and turned off ?
To Joe - will check the bungs now... but i really wanted to avoid this hence im sure i made sure i put them back on properly
Offline NotNormal
« Reply #4 on: August 25, 2009, 01:10:38 pm »
The more heat the better - dry's them out faster
« Reply #5 on: August 25, 2009, 01:36:18 pm »
just dry them out and make sure the bungs are on ok.
once they've dried they shouldnt do it again
  • -Receive: 453
« Reply #6 on: August 25, 2009, 02:19:30 pm »
Take off the rubber covers off and use a hair dryer on the front of the head light to evaporate the condensation.
Offline joesgti
« Reply #7 on: August 25, 2009, 02:31:12 pm »
+1
« Reply #8 on: August 25, 2009, 02:46:56 pm »
have you got any silca gel packets lying around? the sort you get in with shoes etc?
  • -Receive: 453
« Reply #9 on: August 25, 2009, 03:28:54 pm »
You suggesting he should kick his head lights in??    :laugh: :laugh:
« Reply #10 on: August 25, 2009, 03:34:10 pm »
one method i guess  :grin:
no you put the silica beads into a section of a pair of ladies lights and put them into the headlight, you then heat the front causing the water to vaporize and be collected in the beads. then pull the tights out and your done. before silica it was common to use salt, is an age old trick for removing water from the inside of door skins, but the salt is messy
Offline Rich
    • Carpet Underlay
« Reply #11 on: August 25, 2009, 05:35:20 pm »
Ok, ill give all these methods a shot... but ill leave the silca thing till last :grin:
Cheers all the same,  :pomppomp:
Will see which one works :jumpmove:
Offline candy turbo
« Reply #12 on: August 25, 2009, 08:58:01 pm »
hair dryer , best method  :happy2:
