Author Topic: yellow cupra k1, polish testing  (Read 89166 times)
Offline jaffa
  • -Receive: 44
Re:
« Reply #45 on: September 26, 2013, 05:35:27 pm »
I'm going to guess rota grids
Offline Tim144
Re: yellow k1-new wheels ordered
« Reply #46 on: September 26, 2013, 06:16:46 pm »
Grid DRIFTS hopefully!! With loads of concave..
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #47 on: September 26, 2013, 07:01:00 pm »
8.5 front 9.5 rear.
not stretching the fronts much tbh
Tornado red ed30 #0728
Offline cuprajake
« Reply #48 on: September 27, 2013, 08:51:07 pm »
Changed the dv today to the revised g version. Tbh the c was immaculate so perhaps a waste of £30. Time will tell. Car feels no different haha
Wheels are due in Monday, I'm then going to paint them in a custom anthracite/xirrilic mix.
I will need rear camber, luckily I have a hunter so can set it up haha
More work continues on the reverse camera badge, I now have all my bits bar camera due to a cockup at hids4u.
This will be one cool mod
Offline xjay1337
  • -Receive: 377
« Reply #49 on: September 28, 2013, 12:56:43 am »
Will be worth it in the long run Jake the C would have split most likely in a few months.
For the sake of mind I will be changing to rev G once a year. It's £40 and half an hour of fiddling to fit so, just incorporate that into the servicing costs :)
Looking forwards to seeing wheels on.
Offline cuprajake
« Reply #50 on: September 28, 2013, 05:30:37 pm »
started work on the badge.
Just need a few little bits that I got today and some wiring and she's good to go.
Wrong camera was sent so that should be here Monday also, then it's a case of wiring it to the factory rns510 via an adaptor.
Jake
Offline cuprajake
« Reply #51 on: September 30, 2013, 04:32:47 pm »
Offline cuprajake
« Reply #52 on: September 30, 2013, 10:07:11 pm »
Facelift climate control bought. :)
Offline AndrewJB
  • die gelbe Baron
« Reply #53 on: October 01, 2013, 01:36:34 am »
can you code the headunit to work with this then like on the Golf? what head unit you using RNS510? i've got a 310
Offline cuprajake
« Reply #54 on: October 01, 2013, 06:11:35 am »
I've got the rns 510
As far as I'm aware there's no coding. Just swap one pin around.
Offline AndrewJB
  • die gelbe Baron
« Reply #55 on: October 01, 2013, 07:20:38 pm »
Hmm wonder if it will work with the 310 aswell  :wink:
Offline cuprajake
« Reply #56 on: October 01, 2013, 08:38:16 pm »
Sorry,
Replied on my phone this morning and it didn't show you quoted the badge, I thought you meant the climate control
Yes you do need to code the rns510, it's just to tell it there's a reverse camera
The universal camera goes through an interface then into the unit,
It's not complete bar the camera which hids4u have cocked up twice, still waiting for the third attempt to arrive!!!!
I have an electronics genius next door, and he's made me a unit, that will take a reverse feed, then operate the servo, in the meantime it also trips a relay to cut power to the micro switch so the boot doesn't open, so the handle can open more, the power is cut after the handle shuts as the relay has a timed delay in it, so the boot doesn't get accidentally tripped.
I've also ordered a genlabs drl control unit which will drop my drls to 50% brightness, well it will when all the parts arrive for that haha
Final thing is the wheels, they still haven't arrived either, which is annoying, the custom xirrilic colour has been mixed since Monday lol
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=s6hu06dspe7lj8b7gctku2p4kn&/topic,19740.0.html
« Reply #57 on: October 02, 2013, 12:56:43 am »
Cant you just code the brightness of the DRLS?
Offline cuprajake
« Reply #58 on: October 02, 2013, 06:53:40 am »
There not oem rich.
Oem del are the dogs on mine iirc looking on the coding
Offline cuprajake
Re: yellow k1 - wheels are painted
« Reply #59 on: October 02, 2013, 02:55:02 pm »
wheels came in this morning and there stunning.
but were a crappy silver,
id already had my custom colour mixed so prepped the wheels and stuck them in the booth for paint,
here are the results
IMAG0262 by cuprajake1, on Flickr
IMAG0260 by cuprajake1, on Flickr
the colour
IMAG0265 by cuprajake1, on Flickr
and with flash
IMAG0267 by cuprajake1, on Flickr
little trick to keep the bolt holes clean
use a 2p haha
IMAG0270 by cuprajake1, on Flickr
and then your clean
IMAG0273 by cuprajake1, on Flickr
tyres on tomorrow
jake
