Author Topic: Pipewerx downpipes to standard system  (Read 6377 times)
Offline rickyquicky
« on: September 15, 2013, 11:44:28 pm »
To everybody running a pipewerx downpipe to standard system, did it fit straight away using just the exhaust sleeve/clamp thing to mate them up?
I have a pipewerx downpipe, my mechanic attempted to fit it and said it is about 2 foot too short.
It has the reducer built in, but when the old downpipe is removed the join is far back near the rear wheels, the pipewerx downpipe doesn't stretch far enough to mate up to it.
Is there supposed to be another pipe to link the 2? Or are they usually long enough to reach and I have the wrong one?
Offline Gaz
Re: Pipewerx downpipes to standard system
« Reply #1 on: September 25, 2013, 01:56:55 pm »
Youve probably sorted it by now, but..
I had a standard downpipe fitted to a Milltek cat-back, then fitted a Pipewerx downpipe instead. I obviously had to cut the reducer off the Pipewerx but otherwise the joins for exhaust were in the same place as standard downpipe..
Id think the downpipe settings are programmed into the bender or whatever, so every one should be identical!?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: September 27, 2013, 09:49:24 am »
I had a straight bit of pipe 1.5' long which went from my 3" Pipewerx to standard system with a rolled reduced section in it... sold for 99p on ebay! lol
Diesel Daily Hack.
Offline Simon_2.0t
« Reply #3 on: September 27, 2013, 09:56:21 am »
Anyone fitted a 3' decat of ebay to a standard system? (Toyosports etc)
I know when I had my mk4 I had to get an extra bit of pipe fitted.
Are they the same for the mk5, or a direct fit?
Cheers Si
Offline ashw831
« Reply #4 on: September 27, 2013, 10:56:01 pm »
I have got the toyosports one and was a perfect fit, straight to the standard exhaust with no issues. Sounds brilliant too, just fancy a bit more noise, and you can barely hear it at all when cruising or not on boost.
 :driver:
Offline Simon_2.0t
« Reply #5 on: October 05, 2013, 01:30:19 pm »
Cheers mate, will look at these  :happy2:
Offline aarondsg
« Reply #6 on: October 10, 2013, 02:48:54 am »
Toyosports I would say really good
I fitted one to my mates 8p tfsi
Great fitment sounds good
Seemed really good quality
R-Tech Power Stage 2+ Edition 30 (LC9Z)
Offline kahunajb
« Reply #7 on: October 25, 2013, 07:53:21 am »
How much louder are they when mated to a standard cat back are they and is there any drone?
05 Laser Blue Mk5 GTI - Revo Stage 1
Offline aarondsg
« Reply #8 on: October 25, 2013, 08:17:20 am »
No drone whatsoever
Sounds no different on normal driving
Then when you plant your foot down sounds amazing!
Offline akbarirfan
  • -Given: 81
« Reply #9 on: October 25, 2013, 09:53:37 am »
Hi There,
Just looking at the Toyosport down pipe, have you experienced any issues regarding emissions at MOT time? (Just for a down pipe + standard system)
Thanks,
Irfan
Offline aarondsg
« Reply #10 on: October 25, 2013, 04:29:28 pm »
Of course it will fail an emissions test there is no cat there mate it is a decat
if you know a tester some are Ok as long as car is safe elsewhere
Offline akbarirfan
  • -Given: 81
« Reply #11 on: October 26, 2013, 12:25:31 pm »
Ok thanks buddy, just thought there may have been some more CATs along the standard exhaust system after the downpipe that could sort that out  :laugh:
Offline aarondsg
« Reply #12 on: October 26, 2013, 12:56:29 pm »
There is two but the Toyosports deletes both!
It runs all the way back to your backbox
Great bit of kit
Offline akbarirfan
  • -Given: 81
« Reply #13 on: October 26, 2013, 01:13:13 pm »
Ok new to this so real n00b question here, where does the pipe connect to? Is it the turbo, and then straight through to the standard backbox? (If so, seems good for the money, last miltek TBE I saw for the GTI was over £1000!!)
Is a reducer or anything to that effect needed at any stage?
Might check these guys out next time in in Birmingham (not that I have a Golf yet  :grin:)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #14 on: October 26, 2013, 02:47:08 pm »
Turbo to OEM cat back (only the down pipe - hence thread title)
Piperwerx mates with OEM cat back without reducer
