Author Topic: Blow Off Valves  (Read 2704 times)
Offline Brad Gill
    • StreetConcepts
Blow Off Valves
« on: September 23, 2013, 07:19:27 pm »
Alright guys i was wondering if anyone has fitted a Forge or any atmosphere blow off valve to their GTI? Any problems or suggestions about them?
http://www.ebay.co.uk/itm/VW-GOLF-GTI-MK5-2-0-TURBO-FSI-DUMP-VALVE-BLOW-OFF-VALVE-/261282449266?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf%7CPlat_Gen%3AMK+V&hash=item3cd5a5c772
Re: Blow Off Valves
« Reply #1 on: September 23, 2013, 07:25:30 pm »
Yes don't.  :smiley:
Offline Brad Gill
    • StreetConcepts
Re: Blow Off Valves
« Reply #2 on: September 23, 2013, 07:43:08 pm »
will it lower BHP as its not recirculating it back in ? would i be better getting the uprated valve i was reading up somthing about VW made them plastic but better to get one which is metal? Also people saying fit a mk6 one on a mk5?
M7AXB
Re: Blow Off Valves
« Reply #3 on: September 24, 2013, 11:22:50 am »
I had one on my old golf for 2hrs and took it straight back off. It literally sounds like the noise air brakes make on a bus! Don't waste your money!
Money better spent on a revision G diverter valve as this will help with holding boost as I assume you will have the revision C which can fail at anytime.
You can get a bit of turbo chatter with an intake if thats what your looking for :smiley:
Offline Shaun-m
    • www.upandcut.com
Re: Blow Off Valves
« Reply #4 on: September 24, 2013, 07:32:04 pm »
This was something I was also thinking about fitting but to be hionest I really don't no a great deal about them any more info would be great ?
already thinking it seems like a fairly pointless change seems better to save up more  for a intake system ?
Offline CJS-90
Re: Blow Off Valves
« Reply #5 on: September 25, 2013, 09:31:02 am »
A friend had one on his GTi and it sounded gash!
Offline Gaz
Re: Blow Off Valves
« Reply #6 on: September 25, 2013, 01:52:30 pm »
My car has a Forge diverter valve and a Neuspeed intake, they make a lot of whooshing and dumping noises when your going for it, or if you get the turbo spooling up.. Also running stage 2 so higher boost will probably increase turbo noises..
