Author Topic: whining from gt tdi 140??  (Read 6475 times)
Offline ghostgttdi
« on: October 01, 2013, 04:13:55 pm »
hi so I have a golf mk5 gt tdi 140 and theres a sort of whining noise from the front end thinking possible diff problems? or drive shafts? its only really noticeable when at slower speeds and when under braking/ coming to a stop. has any one else experienced this or any suggestions would be great thanks
Re: whining from gt tdi 140??
« Reply #1 on: October 01, 2013, 05:49:19 pm »
could be wheel bearing or the normal turbo trouble
Offline ghostgttdi
« Reply #2 on: October 01, 2013, 09:19:35 pm »
I've just had a rear wheel bearing done it doesn't sound like that did.
when you say turbo trouble what sort of problems do they have? as the cars only done 63k
if it is a turbo problem is it likely to be expensive??
Offline sandancer
« Reply #3 on: October 02, 2013, 07:36:19 am »
Mine needed it's 3rd turbo at 100k miles, sold it on now though.
These cars are notorious for turbo trouble, especially the earlier ones. Meticulous oil services are a must.
A turbo wouldn't really whine when slowing down though, only when it's boosting. Can you here the noise when out of gear and coasting ?
Offline ghostgttdi
« Reply #4 on: October 02, 2013, 11:55:03 am »
yeah it does it when coasting as well its like a kind of binding noise and just gets louder the fast you slow down? im pretty sure its not the turbo but that does have a pretty weird sound when letting of the accelerator like its got a purge valve fitted but its standard???
Offline sandancer
« Reply #5 on: October 02, 2013, 05:22:03 pm »
It's not a sticking brake caliper is it ?
Try jacking each wheel up a spinning by hand, might help you narrow it down
Offline ghostgttdi
« Reply #6 on: October 03, 2013, 02:52:05 pm »
thanks for the help I shall try it tomorrow if it stops raining and let you know, I assume the wheel will be just hard to spin if there is something wrong??
Offline sandancer
« Reply #7 on: October 03, 2013, 05:23:40 pm »
Yes it will be
There will be some resistance anyway, that's quite normal but if you're really struggling to turn the wheel then something could be wrong on that corner
Offline apples12
« Reply #8 on: October 03, 2013, 10:24:21 pm »
is yours a PD or CR?
MK6 GT TDI  - CW - LUX pack
GONE
Offline ghostgttdi
« Reply #9 on: October 04, 2013, 11:08:17 am »
ok so just jacked it up and spun the wheels there was a little resistance but it didn't seem that hard to spin passenger side was quiet but drives side seemed to be a little noisy bit of a grinding sound??
and as for pd and cr I have no idea how would I find this out??
Offline ghostgttdi
« Reply #10 on: October 04, 2013, 11:45:14 am »
ok so done aittle research and I have a pd engine code bkd also when checking unde the bonnet there was a continuous beep noise coming from the inlet manifold is this normal??
Offline apples12
« Reply #11 on: October 04, 2013, 07:50:48 pm »
Get someone to press the accelerator and see if the noise is coming from the high pressure fuel pump, Or any of the pumps. V common on mk6
GONE
Offline xjay1337
  • -Receive: 377
« Reply #12 on: October 04, 2013, 08:00:08 pm »
It's normal for a turbo noise when you let off the throttle after spooling boost..
So when you're braking you get a noise, and the harder you brake the louder the noise gets?
So it's obviously brake related.
Probably low pads, or worn discs.
