Author Topic: radio issue  (Read 1388 times)
Offline pdesai79@hotmail.com
radio issue
« on: October 05, 2013, 10:11:36 pm »
Hi there,
just wanted to ask a question really, since this morning my radio is not turning on when i turn the key in the ignition, wondering whether its an ignition switch issue or some kind of setting that needs changing somewhere.  the car hasnt had any work done on it since january for service/mot.  any ideas?
Offline doylebros
  • -Receive: 310
Re: radio issue
« Reply #1 on: October 05, 2013, 10:30:32 pm »
In your case either a fuse or the radio has failed internally sounds favourite to me  - if you've got access to VCDS scan the vehicle and come back with the results.
Re: radio issue
« Reply #2 on: October 05, 2013, 11:19:12 pm »
well the radio itself works, i just have to hit the on button every time, but i wasnt sure if there was a link between the ignition switch and the radio which meant the radio wouldnt activate like normal
Offline bacillus
  • -Receive: 453
Re: radio issue
« Reply #3 on: October 05, 2013, 11:36:54 pm »
Do you have a standard VW radio?
Re: radio issue
« Reply #4 on: October 05, 2013, 11:51:13 pm »
yeah its the MFD2 sat nav system in there from when the car was bought, never retro fitted
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: radio issue
« Reply #5 on: October 05, 2013, 11:55:24 pm »
get it scanned
sounds like the ignition switch
Cluster and Key coding
Location Great Yarmouth
