Author Topic: Battery replacement  (Read 4470 times)
Offline Panthera
Battery replacement
« on: January 13, 2014, 06:14:40 pm »
I have ordered a new Bosch S5 battery for my GTi.
When I swap them over and re connect the new battery, is there anything I should be ready for...alarm going off etc.. if so, is it a case of pressing the remote lock/unlock?
Darren
P.S. just to clarify, negative off first then positive, then positive on and negative on?
« Last Edit: January 13, 2014, 06:24:39 pm by Panthera »
2007 Blue Graphite Golf GTi
Offline doylebros
  • -Receive: 310
Re: Battery replacement
« Reply #1 on: January 13, 2014, 06:31:53 pm »
Offline Panthera
« Reply #2 on: January 13, 2014, 06:36:43 pm »
How would you do it, or did I miss read something from that link  :confused:
Offline doylebros
  • -Receive: 310
« Reply #3 on: January 13, 2014, 06:38:57 pm »
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #4 on: January 13, 2014, 07:07:00 pm »
Changed my 2007 ED30 battery a couple of months ago , just took one battery out and put the other in , no issues at all apart from when i put the new one in the alarm went off and i just turned it off again with the key  :innocent:
homesqueeze
« Reply #5 on: January 13, 2014, 07:10:50 pm »
When I did mine, the alarm went off when I disconnected the battery and then again when I reconnected it. Just unlocking with the keyfob stopped it when this happened. Also you will get a load of warning lights come on the dash when you first start it again after replacing. These will disappear once you start driving off  :happy2:
Offline martin@gti.co.uk
« Reply #6 on: January 13, 2014, 07:25:34 pm »
Ross tech is recommending to do throtle body adaptation as well. Rest shut be fine. But in some rare cases you might need your radio code as well.
Offline Panthera
« Reply #7 on: January 13, 2014, 07:37:40 pm »
Thanks all  :notworthy: :happy2:
Offline jamma
« Reply #8 on: January 13, 2014, 09:56:35 pm »
Vw took mine off which lost my revo map and then copped a bill from me to pay for a reflash and petrol to go have it put back on . Cheque came through door today actually .
Offline Panthera
« Reply #9 on: January 14, 2014, 07:50:57 pm »
Well, the battery arrived today and I fitted it.  The only small problem that I had was the bracket and getting good purchase on it with my 12mm socket.
The alarm did not go off at all. The only things I had where the steering wheel, ESP and tyre monitoring lights on the dash which went out after a minute of driving slowly. I had to reset the clock and re program the one-shot windows.  The radio was fine.  All's good.
