Author Topic: Fitting Polar FIS +  (Read 17425 times)
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Fitting Polar FIS +
« on: February 13, 2014, 09:43:51 pm »
Hey Guys
Fitted The polar FIS+ today, but it has not worked, also will not let me use vcds, any suggestions chaps?
 :notworthy:
Silver is the way !
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=u69t53lo6lcqg1c1trcgk7g7tc&/topic,19740.0.html
Re: Fitting Polar FIS +
« Reply #1 on: February 13, 2014, 09:48:06 pm »
Take it out and send it to me... ill test it for you!  :innocent:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: February 13, 2014, 09:51:21 pm »
Send me your address :  :wink:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: February 13, 2014, 09:52:19 pm »
Bought it second hand, do they need to be coded in?
Silver is the way !
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: February 13, 2014, 09:57:33 pm »
Hi Neil
Did you check the box "Telematics" in the gateway installation list?
All wires checked and double checked?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: February 13, 2014, 10:07:10 pm »
Hi Neil
Nope, do i have to check the Telematics box in the list then, if so did i need to do that first, before i connected the box?
Is there another way?
Silver is the way !
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: February 13, 2014, 10:16:52 pm »
Has it shown up on the Highline at all?
Scroll through the Highline onto the stock trip screen as VCDS can't communicate when on the polar screen (if that makes sense)
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: February 13, 2014, 10:24:05 pm »
Yeah matey, that's makes sense, no polar screen showing up at all  :confused:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: February 13, 2014, 10:26:50 pm »
when i hit gateway list on the vcds screen, function not supported by gateway!
Silver is the way !
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: February 13, 2014, 10:32:46 pm »
Might need an update from polar to the correct screen for your car. Red dot or white dot.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: February 13, 2014, 10:36:51 pm »
 :drinking: cheers for the helps guys!
Not sure what red dot white dot are?
Do i need to remove it from the car, before i can do an update, or can it be done still connected...?
Silver is the way !
« Reply #11 on: February 13, 2014, 10:38:07 pm »
MK5 will be red dot.. on the highline display  :happy2:
Plug it into your computer and run the update on the polar website.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #12 on: February 13, 2014, 10:40:08 pm »
Seeing as you can't see it in the car probably best to remove and update I would think.
Red dot is the cluster you will have (mk5). White dot (mk6) etc
^^^ what Rich said  :laugh:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #13 on: February 13, 2014, 10:44:53 pm »
Yeah it came from a mk5, i would assume it is red dot.
I can access the polar box, to connect the wire, is it safe to do so whilst connected to the car?
checking for photos !
Silver is the way !
  • -Receive: 445
« Reply #14 on: February 13, 2014, 10:56:28 pm »
i would take it out to update the box--Maybe a daft question but you do have high line display
