Author Topic: How to change Fuel Pump Cam Follower on 2.0 TFSi  (Read 135655 times)
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: How to change Fuel Pump Cam Follower on 2.0 TFSi
« Reply #15 on: October 28, 2009, 04:44:10 pm »
Just over £20. I have got one sat in the garage waiting to be fitted.
Car is standard, FSH, with 26k on clock so I will take some photos of the old follower and add them to this thread if thats ok?
.....please do.Be intresting to see what your's look's like.  :happy2:
Offline Pablos007
« Reply #16 on: October 28, 2009, 08:25:48 pm »
Check out page 8 and 9 of the APR fuel pump fitting PDF, they've tagged on an Audi technical bulletin showing how bad the cam followers can get and the damage it causes. From what I've seen of these, it doesn't seem to make much difference whether you're running a modified the motor or not.
http://www.goapreu.com/support/fsi_fuelpump_installation.pdf
Offline jimmy-s3
« Reply #17 on: January 22, 2011, 10:25:38 am »
Im in the process of doing this now!
Mine doesnt have a pressure valve on the pump?? (2004 mk5 gti)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #18 on: January 22, 2011, 11:06:41 am »
Just be careful then as you will get more fuel coming out when disconnecting the pipes.
Offline jimmy-s3
« Reply #19 on: January 22, 2011, 11:39:29 am »
Just finished it now cheers carl.
Hopefully no leaks etc!
mine was alot trickier than yours i think!?
Offline winrya
« Reply #20 on: January 22, 2011, 01:20:30 pm »
being one of the first gti's, what condition was yours in?
Offline jimmy-s3
« Reply #21 on: January 22, 2011, 01:22:16 pm »
Cant say really?
obviously it doesnt look as new as the brand new one, but it doesnt look too bad for 80K
Offline winrya
« Reply #22 on: January 22, 2011, 01:26:11 pm »
Cant say really?
No holes then :laugh:
That's good news, when I was looking into this, everything I read at the time suggested the early engines were fine, it was the revisions that came with the bwa engine that were the problem.  AXX i'm told had no issues
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #23 on: January 22, 2011, 01:45:58 pm »
What internals are different between the  AXX and BXX engines?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #24 on: January 22, 2011, 01:54:35 pm »
The issues were more with the early AXX engines as they had a chocolate cam lobe.
They altered them to a better grade metal on the BWA engines.
For the sake of £25 part and about 30 mins work it's worth inspecting/changing every 10k miles.  :happy2:
Offline edd666999
  • -Receive: 89
« Reply #25 on: January 24, 2011, 10:45:49 pm »
unless you had massive problems with your fuel pump leaking and now its working you dare not touch it  :signLOL:
Offline damoegan
« Reply #26 on: January 31, 2011, 03:56:52 pm »
Great guid, Carl  :happy2:
Took me a whole 30 mins today including changing the sparks  :grin:
ALso my car is a Jan 07 car and covered 48k and only showing a very small amount of ware on the inside of the follower  :smiley:
« Last Edit: January 31, 2011, 03:59:22 pm by damoegan »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=r4i77c3n4lveeh5nvtubv7itbf&/topic,19740.0.html
« Reply #27 on: April 13, 2011, 12:48:32 pm »
BTTT
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #28 on: April 13, 2011, 10:02:08 pm »
Anyone with an early (two metal pipe) fuel pump done this and if so how does it differ from the one metal / one rubber pipe pumps?
Sepang Blue S4 BE Avant
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #29 on: April 13, 2011, 10:08:54 pm »
It's harder to do is the main thing.
Other than the physical changes to the pipe that's about it.
Stu...
