Author Topic: Dazza's Maintenance Thread  (Read 111663 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fiisal21blti1rnp35u86lmpm0&/topic,90967.msg917089.html#msg917089
Re: Dazza's Maintenance Thread
« Reply #150 on: June 03, 2015, 03:48:12 pm »
Spent the best part of a week polishing the car. It's a bit better than last time.
Once i got her out in the sun. I noticed a few areas where i didn't buff off the sealant properly.
Pity i cant take a good photo.
Don't think my bumper is straight.
« Last Edit: June 03, 2015, 03:53:06 pm by dazza »
05 | Tornado Red | DSG
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #151 on: June 03, 2015, 04:09:03 pm »
Looks great! Just like new! :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=fiisal21blti1rnp35u86lmpm0&/topic,19740.0.html
« Reply #152 on: June 03, 2015, 04:13:16 pm »
 :smiley:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #153 on: June 03, 2015, 04:21:02 pm »
Thanks guys how do i go about getting the bumper straight??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #154 on: June 03, 2015, 04:28:05 pm »
I did a really good job on the roof 99% perfect the rest not so much. Think the drivers door has been resprayed as getting paint on the pad so didn't hit this with any hard pads or polish just a finishing pad.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #155 on: June 03, 2015, 07:13:29 pm »
Not sure what you mean about the bumper not being straight. You might try to release the bolts and retorque them with the bumper in the correct position with the help of someone else.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #156 on: June 03, 2015, 08:01:07 pm »
look at the gap on the left compared to the right.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #157 on: June 03, 2015, 08:08:23 pm »
Yeah, you might want to try to partially remove the bumper and then refit it properly. Something is out of its place in the left side. :smiley:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #158 on: June 12, 2015, 01:26:59 pm »
Not much to report lately. Car is running better than ever hopefully i will have a couple of thousand kilometres without something breaking.
The Koonlung K1S arrived today. Will be getting this installed next week. It seems to be a good quality kit.
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #159 on: June 12, 2015, 01:41:58 pm »
regards bumper allignment, maybe trick of the light but looks like headlight too. if it is, it's probably slam panel mis alligned, you may need to adjust left and right to get it sitting evenly.
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #160 on: June 12, 2015, 01:54:35 pm »
Don't get me started u know i have OCD.  :signLOL: There is a bigger gap between the bonnet and light on the left had side. But the bonnet also sits fractionally higher on the left.
Offline olethalb
  • -Receive: 31
« Reply #161 on: June 12, 2015, 03:06:52 pm »
i'm a little OCD too, if it is slam it's easy adjusted and bonnet will just be the rubbers in the front corners need turning in/out to suit  :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #162 on: June 12, 2015, 03:14:17 pm »
Does the bumper have to come off to adjust the slam panel?
Offline olethalb
  • -Receive: 31
« Reply #163 on: June 12, 2015, 03:19:34 pm »
shouldn't for this as long as it's a simple case of back / forward allignment, the slam is bolted on at each side above the headlights, the bolt holes are enlarged so allows you a little wiggle room, just loosen them off - pull / push the direction you want it, nip up bolts while holding and see how it looks. as i say it may be a case of left out and right in a little to get it sat evenly but i'm sure you'll see when you do it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #164 on: June 12, 2015, 03:36:52 pm »
Thanks mate will add it to my todo list.
