Author Topic: Candy White Golf GTI Ed. 30 - 8th track day at Estoril  (Read 294614 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« on: April 04, 2015, 09:44:16 am »
Hello again! After the diesel GT Sport I had to get the best petrol version. :grin:
So I'm the new owner of a Candy White 3 doors Ed. 30 with DSG MY2008. Most likely the only in my country with this colour. It's pretty much in mint condition and has less than 35.000 miles.
I already have a long list of mods to do and some were already ordered.
Here's an old picture. The previous owner made some changes to the centre grill and wheels but I'll return them to OEM look and fit my OZ instead.
My wife will have the diesel most of the times and we'll use it for long distance travels as well.
Factory equipment:
  • Leather flatbottom MFSW with red stitches
  • Leather golf ball style DSG gearknob
  • Leather handbrake handle with red stitches
  • Electric and heated half leather sport seats
  • Front under seat drawers
  • Front footwell lighting
  • Front and rear armrest
  • Front cup holder and bottle opener
  • Rear cup holder
  • Right rear door ashtray
  • Front electric windows
  • Highline cluster
  • Cruise control
  • Aux-in outside the armrest
  • Aluminium pedals
  • Ed. 30 front door sill scuff plate protectors
  • Ed. 30 badge in the aluminium trim above glove box compartment
  • Fog lights
  • Light and rain sensor
  • Follow me home
  • Electrochromatic rear-view mirror
  • Climatronic dual-zone climate control -> upgraded
  • BYD engine: 2.0 TFSI 230 CV/300 Nm
  • Turbo K04
  • 20 mm lowered sport suspension -> upgraded
  • Electromechanical steering
  • ABS with ESP and ASR
  • Front brakes with 312 mm vented discs -> upgraded
  • Rear brakes with 286 mm solid discs -> upgraded
  • Wheels: Pescara (BBS) 7,5''x18'' 5x112 ET51 -> upgraded
Factory options:
  • DSG DQ250 6 speed (KNB)
  • Xenon lights with self-leveling system and washers
  • RNS-510 version A -> upgraded
  • 6 discs changer inside front armrest
  • Bluetooth kit (5N0035730) -> upgraded
  • Electric folding side-view mirrors with puddle lights
  • Rear parking sensors -> upgraded
  • Alarm with volumetric-motion sensors
  • Passive TPMS
Modifications done:
Exterior:
  • Centre grill 3M black carbon fiber wrapped -> removed
  • Side mirrors covers 3M black carbon fiber wrapped -> removed
  • Front spoiler with lip painted gloss black
  • Rear spoiler with central lower section painted gloss black
  • Side mirrors covers painted gloss black
  • Front and rear red GTI badges
  • Edition 30 badge on the centre grill
  • GTI seat inserts
  • LED sidelights (6000K)
  • LED wing mirror puddle lights (6000K) -> upgraded
  • Full LED wing mirror puddle lights (6000K)
  • Mk6 Golf LED numberplate lights (1K8943021C)
  • LED brake and parking lights
  • LED reverse light (6000K)
  • Short aerial
  • OEM rear bumper without sensor holes with holes made to fit OPS sensors
  • Mk5 Golf Bluemotion rear axle cover (1K0501713C; 1K0501682; N90548305; N90183802)
  • Full engine undertray from the mk5 Golf R32 (1K0825237P; (3x) 1K0825951)
Interior:
  • PolarFis Advanced (PF03) -> upgraded
  • PolarFIS Advanced PF04
  • RNS-510 version R
  • RNS-510 firmware upgrade to modified version 6276 with secret menu and VIM activated
  • RNS-510 V16 maps (2019)
  • Custom POI with speed cameras made with POInspect0r
  • Bluetooth kit upgrade (7P6035730M) with Polar BT/Battery module for MFA+ display
  • Mk6 Golf climatronic and Jetta mk6 trim
  • Mk6 Golf OPS parking sensors front and rear
  • Mk6 Golf rear view camera
  • Mk6 Golf brushed metal tipped headlight, windows, wing mirrors and fuel door switches
  • Complete interior LED set (6000K)
  • Rear footwell lighting with LED
  • Door warning lights with 3D LED
  • Cherry red hazard switch
  • DSG paddles extensions
  • OEM Golf front and rear rubber mats
  • OEM boot tray (1K0061180)
Engine:
  • TTE420 K04 hybrid turbo
  • Bigger OEM DSG cooler (02E409061C) with 18 lines instead of 10
  • AKS Tuning VAG TFSI cam follower to TSI cam follower roller conversion kit
  • Custom painted Audi TTS engine cover
  • OEM black coolant expansion tank cap (5Q0121321)
  • Diverter valve relocation to the front of the engine and noise generator removal
  • Revision G diverter valve -> upgraded
  • Go Fast Bits DV+
  • Go Fast Bits lightweight crank pulley -> removed
  • Fluidampr Engine Damper - 2.0 TFSI
  • ITG Profilter panel filter (WB586) -> upgraded
  • OEM airbox lower face insulated with heat insulation tape -> upgraded
  • VW Racing cold air intake (VWR12G5GT)
  • Darkside Developments S3 uprated IC with alloy end tanks and silicone boost hoses -> upgraded
  • do88 2.0 TFSI intercooler
  • NGK Iridium BKR7EIX spark plugs
  • R8 red ignition coil pack set
  • LOBA's HPFP
  • RS4 fuel pressure return valve -> upgraded
  • AKS Tuning 165 bar fuel pressure return valve
  • DeatschWerks DW65v LPFP
  • CTS Turbo intake manifold runner flap delete kit
  • CTS Turbo throttle pipe
  • CTS Turbo turbo outlet pipe
  • Forge Motorsport oil catch tank system for vehicles with charcoal filter (FMMK5CTC)
  • Redirected EVAP return fuel line due to Forge Motorsport oil catch can
  • ECS Tuning billet aluminium oil filter housing kit 2.0T
  • ECS Tuning magnetic sump plug
  • Modified Creations Motorsport exhaust manifold heat shield
  • BCS Powervalve TBE Prestige system with 200 cell cat and wrapped downpipe
  • Custom remap to 3XX CV and XXX Nm (XXX LbFt)
  • Custom DSG remap
Handling:
  • MFactory LSD for DSG with 25 tooth parking brake ring (MF-TRS-05DSG6)
  • Eibach Sportline springs -> replaced
  • Koni Sport dampers -> upgraded
  • H&R Sport -30 mm springs (29176-1) -> upgraded
  • H&R sway bars 26/22 mm (33258-1)
  • Passat aluminium control arms (2x 3C0407151G)
  • Passat B6/S3 8P aluminium hubs (3C0407257F and 3C0407258F)
  • Passat/S3 ball joints (3C0407365B and 3C0407366B) -> upgraded
  • SuperPro adjustable ball joints (TRC0003)
  • VW Racing adjustable front drop links (VWR42G500)
  • SuperPro adjustable rear drop links (TRC1045L)
  • PowerFlex front suspension arm front bush
  • PowerFlex front suspension arm rear bush -> upgraded
  • SuperPro anti-lift kit with "Supaloy" brackets
  • Audi TT/RS3 front upper strut mounts
  • Mk5 Golf R32 front bump stops -> removed
  • Subframe bolts and shims (N90823501 and 7M3499349A) -> upgraded
  • Vibra-Technics bottom engine mount/Subframe mount (VAG520M)
  • Vibra-Technics dogbone mount (VAG455B)
  • Powerflex engine and gearbox mounts inserts (PFF85-530 e PFF85-532)
  • TyrolSport deadset rigid front subframe collar kit (TSDSKVW)
  • TyrolSport deadset rigid rear subframe collar kit (TSDSKVWR)
  • Addiction Motorsport under brace bar
  • SuperPro rear enhancement bush kit (KIT5238RK)
  • R-Tech rear brace bar
  • Brembo 18Z calipers painted red (Foliatec) and with Brembo lettering -> upgraded
  • Epytec's mounting kit for Brembo calipers -> upgraded
  • HEL braided brake lines for Brembo calipers -> upgraded
  • ATE 350 mm MB GL450 front vented discs with centering rings -> upgraded
  • EBC Redstuff front brake pads for Brembo 17Z -> upgraded
  • Carbotech XP20 front pads for track use -> upgraded
  • TTRS 8J calipers painted red with GTI lettering (8J0615107A; 8J0615108A)
  • Front 2-piece 362x32mm disc & caliper carrier kit - allows fitment of 4 piston TTRS/RS3 Brembo calipers (DI0003)
  • PFC 11 compound brake pads (1001)
  • Brake pads mount kit (8J0698269 x2)
  • RS3 suspension control arm air ducts (8P0863149B; 8P0863150B; N10422203 x2; N90761102 x2; 8P0864133A x2)
  • R32 rear calipers and carriers painted red (Foliatec)
  • ATE 310 mm rear vented discs
  • Ferodo DS2500 rear brake pads
  • HEL braided brake lines for rear calipers
  • ATE SL.6 DOT4 brake oil -> upgraded
  • Motul RBF 600 racing brake oil -> upgraded
  • Castrol React SRF Racing brake oil
  • OZ Ultraleggera 8Jx18'' 5x112 ET45 Matte Graphite Silver
  • Continental SportContact 5 225/40R18 92Y -> upgraded
  • Michelin Pilot Super Sport 225/40R18 92Y
  • 16x Wheel bolt covers (321601173AZ37) and 4x locking wheel bolt covers (4F0601173AZ37)
  • Team Dynamics Pro Race 1.2 Gloss Anthracite 8Jx18'' 5x112 ET45 for track use
  • Federal 595 RS-R 225/40R18 88W for track use -> upgraded
  • Yokohama Advan Neova AD08R 225/40R18 88W
Maintenance done:
  • Intake manifold, injectors and valve stems cleaned
  • Cam belt kit and water pump replaced
  • Replaced all thermostats and temperature sensors
  • Oil, fuel and cabin filters
  • Millers Oils CFS Nanodrive 5w40 NT 5L -> replaced
  • Motul 300V Power 5w40 6L
  • Replaced front ball joints -> upgraded
  • Replaced rear control arm lower bushings -> upgraded
  • Replaced rear upper shock mounts
  • Replaced front bushings of the rear trailing arms -> upgraded
  • Full front respray
  • New license plates
  • New AC condenser, AC compressor and AC gas pressure sensor
  • Replaced the HPFP cam follower -> upgraded
  • New revision engine oil dipstick (06F115611F)
  • Steering rack Gen 3 (1K0909144R)
So far I've removed the carbon wrap of the VW front badge, fitted OEM LED numberplate lights, fitted the OZ and updated the RNS-510's firmware, maps and POI.
Here's the output with the stock map and the following mods:
  • CM Exhaust manifold heat shield
  • BCS Powervalve TBE Prestige system with 200 cell cat and wrapped DP
With all the mods fitted so far the car is making 330 BHP and 457 Nm/337 lbf*ft, with 1,4 bar of peak boost and 1,24-1.21 bar of stable boost.
Future plans:
At home:Ordered:
    Still not ordered:
    • Interior detail cleaning
    • Exterior detail cleaning
    Offline prp74
    • -Receive: 126
    Re: Candy White Golf GTI Ed. 30
    « Reply #1 on: April 04, 2015, 04:42:35 pm »
    Very nice mate. Get some more pics up.
    Stunning  :congrats:
    Offline rex
    • -Given: 50
    • -Receive: 74
    « Reply #2 on: April 04, 2015, 06:32:48 pm »
    Not a small list of mods....  :notworthy:
    Best of luck and keep us posted!
    And please remember:
    :worthless:
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #3 on: April 06, 2015, 03:35:58 am »
    Yeah, you're right, this is still very poor on pictures but only Thursday I had my OZ fitted and I didn't have any good chance to take them yet. :|
    Managed to update the factory fitted RNS-510 version A to a modified firmware that gives more disc space for maps, allowing to install the current V12 (2015) maps. Link for the firmware: http://www.rnsfirmware.com/firmware-4020-for-older-units-in-europe-with-hdd-rations-60355/
    I had to use a CD-R from Verbatim do get the unit to read it properly. It didn't like the CD-RW from Sony that I used previously to update a previous version B and my current version P. Fortunately it liked the DVD+R DL from Memorex and copied all of the maps at the 1st attempt.
    I'll try to take pictures soon, before it starts to rain like it's forecasted.
     :smiley:
    Offline Golf_GT_TDI
    • -Given: 45
    • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
    « Reply #4 on: April 06, 2015, 09:36:39 am »
    Very nice indeed, love the colour  :happy2:
    dansmith180
    « Reply #5 on: April 06, 2015, 12:03:04 pm »
    Lovely car mate, give it a good clean and get some more pics up soon  :happy2:
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #6 on: April 06, 2015, 01:09:38 pm »
    As forecasted it started raining today. I'm glad I took some pictures early today. I didn't have time to give it a proper clean but it'll do for now. I'll upload them later today.
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #7 on: April 07, 2015, 02:03:49 am »
    Updated the 1st post with the pictures I took early yesterday. :smiley:
    Tomorrow I'll have something to pick up from UPS, not even sure what it is. :laugh:
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #8 on: April 08, 2015, 07:33:53 pm »
    Yesterday started fitting new bits in my new machine. :smiley:
    Got an OEM boot tray (1K0061180) and a neighbor was nice to give me an OEM boot net and an OEM first aid kit that the previous owner must have taken.
    Bought new rubber mats but VW updated them to the ones from the mk7 Golf. Tried one for the rear and it didn't fit properly. Compared the one for the driver with my carpet mat and it was nothing alike as well. I'll return them tomorrow. Fortunately a friend in a different city was able to get the "old" rubber mats for me today.
    Also asked for an Edition 30 boot badge and VW stopped producing them in June of 2014. Searched online and they already started to be overpriced almost everywhere.  :surprised: Still managed to order a pair for less than Mandy and others are asking in ebay for just one. :confused:
    Offline GTiBlues
    • Mr Blues
      • Bookface
    • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
    « Reply #9 on: April 08, 2015, 07:54:10 pm »
    Mind me asking, whats the buttons for next to the glasses pocket?
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #10 on: April 08, 2015, 08:27:21 pm »
    They are connected to the Bluetooth module. The biggest is for voice control, the other for Assistance and the other for Information? I don't have an old cellphone to synchronize with this Bluetooth module so I'm not 100% sure.
    When I have time to read the manual or get the new module it'll be easier. :laugh:
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #11 on: April 09, 2015, 01:03:21 pm »
    Sorted the problem with the rubber mats. After all the VW Parts clerk made a confusion and gave me the mats that another person ordered. They have a very similar part number and he thought those mats were for me, not noticing the different part number.
    So I returned them and since I ordered parts to renew the suspension, I'll get their value discounted when I pick up those parts.
    Since my friend already got the correct ones I'll receive them soon. :laugh:
    Too much trouble for such simple thing but will all end well. :signLOL:
    Offline joms6r
    • My Ride: Golf 6R
    « Reply #12 on: April 09, 2015, 11:47:57 pm »
    Lovely looking car mate, not sure where abouts you are but there are some lovely roads down the Algarve.
    R-tech powered Mk6 Golf R
    ** Mk5 GTI Track build: >>Here<< **
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #13 on: April 10, 2015, 12:00:08 am »
    Thanks mate! I'm in Lisbon so I can go to the hills near Sintra that have some lovely roads in the natural park. But first I want to sort the suspension as I feel the car too bouncy for my taste. The GT Sport with its upgraded but still comfortable suspension handles better at the moment. :confused:
    Offline Shoduchi
    • -Given: 220
    • -Receive: 430
    « Reply #14 on: April 10, 2015, 07:33:03 pm »
    Arrived home to see this in the hall:
    The good stuff is starting to arrive! :jumpmove:
