Author Topic: Porsche Panamera calipers adapters for mk5  (Read 5388 times)
killer666
« on: September 07, 2015, 03:33:13 pm »
I want to mount the Panamera 6pot calipers on my mk5, but I can't seem to find adapters for them, I will be using them with the ML 350mm discs
Did you guys try this on your cars?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Porsche Panamera calipers adapters for mk5
« Reply #1 on: September 10, 2015, 05:07:33 pm »
Wouldn't it be easier and cheaper to get Porsche Cayenne's 6 pot calipers? There are lots of sellers for the adaptor bolts...
killer666
« Reply #2 on: September 10, 2015, 05:13:24 pm »
No:) because I already have the panamera calipers:)
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: September 10, 2015, 05:18:57 pm »
I'm not sure there is any yet, but contact someone like Vagbremtechnic to see if they can help you out.
https://www.facebook.com/vagbremtechnic
Also worth seeing if the ML350 discs will work wih those calipers, as mentioned they work for the Cayenne 6 piston calipers so may also work. Saying that, if the calipers you have are only slightly different in shape, may offer them up to the hub and see, as when fitting Cayenne calipers to a mk5/6 hub you just need the adapter bolts, no brackets...
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: September 10, 2015, 05:27:25 pm »
Some further Google searches showed this:
https://www.google.co.uk/search?q=vw+golf+cayenne+brakes&biw=1600&bih=775&source=lnms&tbm=isch&sa=X&ved=0CAYQ_AUoAWoVChMItJaQgvDsxwIVJpvbCh0XVwi_#imgrc=_
Now I searched for 'Cayenne' calipers but clearly some of the images are of the same calipers you have, so I'd imagine it's a similar build to the Cayenne 6 pistons. All you'll need then is bolts and lines:
Bolts - http://www.ebay.co.uk/itm/Vw-Golf-Mk5-Mk6-Mounting-Bolts-for-Porsche-Cayenne-Calipers-Audi-Q7-Brembo-/111067552499?hash=item19dc245af3
Lines - http://www.ebay.co.uk/itm/VW-Golf-Mk6-R-GTI-TDI-to-Porsche-Caliper-Conversion-Front-HEL-Brake-Lines-/231480180702?hash=item35e54b3fde
I can't say for certain these will work, but it's my best guess...
killer666
« Reply #5 on: September 10, 2015, 05:30:27 pm »
I need adapters, without them i'm not able to mount them on the hub
Offline th3_f15t
  • -Receive: 183
« Reply #6 on: September 10, 2015, 05:41:38 pm »
Ah, yes... I see now. As said, contact Vagbremtechnic...
