Author Topic: Cam chain, tensioner... How to determine adjuster??  (Read 22806 times)
Offline graham-gti
Re: Cam chain, tensioner... How to determine adjuster??
« Reply #30 on: October 18, 2015, 05:25:02 pm »
Ok cool. I can't hear it from in the car so hopefully it's just the injectors
Offline Pesky jones
« Reply #31 on: October 18, 2015, 05:25:28 pm »
Probably is
Offline GTI Dave 30
« Reply #32 on: October 18, 2015, 08:34:02 pm »
Hi is it a comon problem  on edtion 30 if so whats the average mileage  people have changed them at thanks.
Offline Pesky jones
« Reply #33 on: October 18, 2015, 08:41:34 pm »
There technically never meant to be changed. You only change them if it shows symptoms
Offline GTI Dave 30
« Reply #34 on: October 18, 2015, 09:04:14 pm »
Thanks seams quite  enough  with 62k on.
Offline JamieBiz
  • Hiss, Pop, Gone...
« Reply #35 on: October 19, 2015, 08:27:20 am »
My Gti has 62k on the clock and ill be changing them as soon as i can afford it. it sounds like a tractor when im idling
Offline -AC-
« Reply #36 on: October 19, 2015, 01:51:46 pm »
Just received the T40080 tool I was waiting on so will get cracking on with this on Friday.
I know there are already guides on this but might fire one up as a go along.
Offline Pesky jones
« Reply #37 on: October 19, 2015, 02:27:14 pm »
good luck and yeah the more guides the better
Offline JamieBiz
« Reply #38 on: October 19, 2015, 04:36:27 pm »
Can you make it as idiot proof as possible please  :notworthy:
I 'may' attempt this if its not too bad to do.
Offline Paradox1
  • -Given: 41
« Reply #39 on: October 19, 2015, 04:57:52 pm »
How much extra is the adjuster?
surely it would make more sense to replace the chain, tensioner and adjust?
Its not just the noise that you want to get rid of but you'd want to increase the reliability?
  • -Receive: 691
« Reply #40 on: October 19, 2015, 04:59:14 pm »
Don't forget the cam locking tool as well - T10252.
I think the main reason for replacing the adjuster is when the bolt head rounds out, which can happen as it's feckin tight by all accounts.
Offline doylebros
« Reply #41 on: October 19, 2015, 05:59:23 pm »
Worth a read if your going to do it yourself - http://www.mk5golfgti.co.uk/forum/index.php/topic,97333.0.html
Offline bimbound
« Reply #42 on: October 20, 2015, 10:27:39 am »
The adjustor is approx. £400 just for the part. Apparently there are fewer issues with this part than the chain/tensioner and the adjustor will 'normally' flag a code in VCDS if it is faulty. Its a sealed unit so cannot be inspected.
If it was a £30 part like the water pump is when replacing the cam belt i'd say sure replace it, but IMO increasing the bill from IRO £350 to IRO £800 is just not worth it for something that may never need replacing.
Offline Pesky jones
« Reply #43 on: October 20, 2015, 10:54:10 am »
you can fark the adjustor bolt, and end up having to drill the head off, but then you would just replace the adjustor bolt - not the actual adjustor, right?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #44 on: October 20, 2015, 11:02:42 am »
I had to drill mine off.  :sick:
The adjustor has holes where the bolt is these got full of shavings.
IMO if you manage to drill off bolt without damaging the adjustor replace it anyway. I took mine apart and it had metal shavings inside.
Just incase someone has to drill it off 13mm drill bit will do it.
05 | Tornado Red | DSG
