All Things Mk5 > Performance Modifications
DSG remap question
flashp:
--- Quote from: Shoduchi on April 22, 2016, 01:28:11 pm ---
--- Quote from: Paradox1 on April 22, 2016, 01:22:02 pm ---
--- Quote from: Shoduchi on April 22, 2016, 01:04:48 pm ---Mine needed the torque limiter changed to make remap work well. The box was "cutting" the ignition timing, preventing the engine to make more power and torque.
--- End quote ---
Ahh I see, thanks.
Once your car DSG has been mapped is there any change is tone? just curious
--- End quote ---
The engine sounds raspier and quicker to respond to the throttle input but I think that it's just related to the increased boost and fuelling, nothing related to the DSG remap itself.
--- End quote ---
I had a full set of Revo engine mounts done and that changed power delivery and engine noise in the car. You can feel the engine vibrations (only just) through your fingers on the wheel at idle. The engine is restrained in it's mounts so there is no inertia generated by soft mounts to overcome when on the throttle. These engines move around a lot on stock mounts. On a modified car that's driven OE mounts are worked very hard. The noise in the cabin is very addictive, creates a 'growly' engine noise. I love it, some may not. Car is very sharp on the throttle though. :happy2:
Shoduchi:
--- Quote from: flashp on April 22, 2016, 02:13:41 pm ---I had a full set of Revo engine mounts done and that changed power delivery and engine noise in the car. You can feel the engine vibrations (only just) through your fingers on the wheel at idle. The engine is restrained in it's mounts so there is no inertia generated by soft mounts to overcome when on the throttle. These engines move around a lot on stock mounts. On a modified car that's driven OE mounts are worked very hard. The noise in the cabin is very addictive, creates a 'growly' engine noise. I love it, some may not. Car is very sharp on the throttle though. :happy2:
--- End quote ---
Yeah, I forgot about those. I've only upgraded both dogbone's mounts to Vibra-Technics and that made a good difference to the engine response. My Eddie only has 38.500 miles so I think the top engine mounts are still ok. When they're a bit more tired, I'll upgrade them as well. Thank you for your input to the topic! It's always high quality. :happy2:
Beej:
--- End quote ---
Ahh I see, thanks.
--- End quote ---
I have been told that having it mapped reduces if not totally eradicates the farts/pops on gear change. One of the reasons why I haven't went with one, as I like having that when your giving it some!
Shoduchi:
--- Quote from: Beej on April 22, 2016, 09:16:48 pm ---
--- End quote ---
Ahh I see, thanks.
--- End quote ---
--- End quote ---
I haven't seen any video with a DSG remapped and no fart at gear change. Mine keeps farting, the more boost the merrier, but I know it wasn't much changed so far (most likely just the torque limiter...).
Beej:
--- Quote from: Shoduchi on April 22, 2016, 09:32:26 pm ---
--- End quote ---
Ahh I see, thanks.
--- End quote ---
--- End quote ---
I haven't seen any video with a DSG remapped and no fart at gear change. Mine keeps farting, the more boost the merrier, but I know it wasn't much changed so far.
--- End quote ---
Have you got a dsg remap?
Navigation
[0] Message Index
[*] Previous page
Go to full version
