All Things Mk5 > How to Guides / Troubleshooting
Alarm not working
<< < (2/2)
RetroRaz:
Any luck?
Sent from my SM-G928F using Tapatalk
kam:
Ok test update I liked in the fuse box in the car and there were a number of spaces left don't know what made me do it but I placed a fuse in the empty spaces and hey presto the siren worked but not properly which indicated the second hand siren was knackered .
I tried the old siren and that didn't work either so I bought a new one and it works the interior sensor is working to .
But I want to know if the alarm should be self arming with a delay if you forget to turn it on ??
RetroRaz:
It doesn't self arm, only if you have unlocked the car by mistake after arming it. It will then self lock and arm
ady-uk:
It's the alarm unit, under front wing.
DO NOT buyt second hand......totally false economy!
I had exactly same three errors.
Bought new from TPS.....fitted....all working fine now!
Main reason I noticed it not working, but wanting it working, was due to enabling unlock / lock chirp :D
r5gtt:
I have the exact fault code as op has. Alarm not working interior sensor etc.
Navigation
[0] Message Index
[*] Previous page
Go to full version
