Author Topic: URGENT oil pressure stop engine  (Read 235609 times)
Offline Pesky jones
« on: February 27, 2016, 09:52:23 am »
At a track day, first lap I get tge warning message stop oil preseure low, engine off. Pulled off the track, as I was coming to a stopthe engine cut out!
wont turn back on. Currently sitting in cafe wondering what to do.
« Last Edit: December 29, 2016, 11:36:52 pm by Pesky jones »
« Reply #1 on: February 27, 2016, 10:00:16 am »
And you checked the oil level?
Do you have polar FIS? Does that show oil pressure? Can't remember.
Oil pickup?
Offline dronners
« Reply #2 on: February 27, 2016, 11:36:57 am »
you've probably got a blocked oil strainer in the sump
Offline Pesky jones
« Reply #3 on: February 27, 2016, 11:55:17 am »
@dronners
What makes you say that?
Car wont turn on now, just ticks over
Offline Pesky jones
« Reply #4 on: February 27, 2016, 12:22:45 pm »
When it was on it sounded mega rattly.
I mean normally it sounds a bit rattly but no where near what it sounded like today
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: February 27, 2016, 12:30:15 pm »
Cam sensor error comes up when your oil strainer is blocked and there's no oil pumping into the cylinder head  :surprised:
If you have any tools?, try turn the crank over manually with socket and rachet.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: February 27, 2016, 01:21:55 pm »
@Peskyjones  if it's the chain it would still run and rattle very loud from what I've read and heard over the years. did you really turn the car off or did it cut out on you as ive had this with a car and tried to drive it off the motorway and the car was rattling like f*** in the end engine seized.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: February 27, 2016, 01:27:33 pm »
this isn't good  :sad1:
hopefully its something simple.
05 | Tornado Red | DSG
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: February 27, 2016, 02:16:37 pm »
Could be the chain although you shouldn't have restarted her mate. that's the oil sign that tells you to stop the car meaning DO NOT attempt to start it again as its been discussed 100's of times as it's a failure and you should diagnose and rectify the fault before attempting to restart it which a lot of people fail to realise  :sad1: and by then it's too late and major damage is done.
Above in the first post you said quote 》》》 I was coming to a stopthe engine cut out!
wont turn back on!
but now you're saying 》》》 . I then turned the car off and checked the oil level. Oil level was fine. Turned it back on and drove to the paddock and as I was coming to a stop it cut out!
« Last Edit: February 27, 2016, 02:24:15 pm by r5gtt »
Offline Pesky jones
« Reply #9 on: February 27, 2016, 02:25:50 pm »
Yeah I know :( The warning went when I turned it back on but still sounded like sh*t. Drove about 300 hundred yards before it cut out.
Offline Nasir
« Reply #10 on: February 27, 2016, 02:26:31 pm »
I came off the track when I saw the warning. I then turned the car off and checked the oil level. Oil level was fine. Turned it back on and drove to the paddock and as I was coming to a stop it cut out!
Waited for it to cool down, scanned it and got the p0011 cam shaft a code. Tried to turn it on and it was just ticking over, rpm hardly budging, maybe 2-300 rpm. Now in the tow truck :(
Don't try to start it with an oil pressure fault. Not the same car, but my sister's 1.6 FSI kept flashing up with the STOP oil pressure light. Had the oil changed and it's been fine since. That being said, her car had no fault codes.
Shadow Blue 2007 GTI DSG (Standard)
Offline Pesky jones
« Reply #11 on: February 27, 2016, 02:27:52 pm »
Yeah sorry I got it wrong, I wasnt thinking properly when typing the first post. My bad
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: February 27, 2016, 02:56:22 pm »
I'll let you off as it's a very stressful situation  :sad1:
hope you haven't done too much damage but my guess is ypu have already done it.  :scared:
Offline callis
« Reply #13 on: February 27, 2016, 03:44:48 pm »
100% blocked oil pick up pipe, Drain oil, take of sump and give it a good clean or replace strainer about £70 from dealers
then you just need oil and sealent  :happy2:
wont be anything else, esp if oil level fine and no oil in your coolant
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline Pesky jones
« Reply #14 on: February 27, 2016, 04:33:37 pm »
Well that is music to my ears, but what makes you so sure?
