Author Topic: Aux belt tensioner  (Read 8782 times)
Offline Dale
Aux belt tensioner
« on: February 27, 2016, 12:45:28 pm »
Hi all,
Think I've narrowed down the slight ticking noise on my car to be the Aux belt tensioner,
Was just wondering how easy is it to replace?
Offline skard
  • -Receive: 245
Re: Aux belt tensioner
« Reply #1 on: February 27, 2016, 03:50:08 pm »
Usually it is the alternator pulley causing a tick, is it at idle/low revs?
Offline Dale
« Reply #2 on: February 28, 2016, 12:08:08 pm »
Yeah it is. Can see the tensioner wobbling though hence why I thought it was this?
Offline skard
  • -Receive: 245
« Reply #3 on: February 28, 2016, 04:49:50 pm »
First time I changed one it had the tensioner bouncing all over, you could remove the belt tension and see if your alternator pulley only rotates one way (good) or both ways (bad)
Offline ALIAHMET
« Reply #4 on: February 29, 2016, 09:22:01 am »
I got the same issue on my 1.9 tdi. Plan to replace the alternator and belt at the same time.
The weather has been sooo cold! I have been putting it off, as its only ticking - not actually causing an issue - Yet......
Offline Dale
« Reply #5 on: February 29, 2016, 12:16:22 pm »
Ok mate cheers. How do you release the tension?
Offline Dale
« Reply #6 on: February 29, 2016, 12:17:12 pm »
Yeah same here. Want to get it done sooner rather than later though.
Offline skard
  • -Receive: 245
« Reply #7 on: February 29, 2016, 12:19:50 pm »
You need an open ended 15mm(?) spanner on the swuad bit on the tensioner, take it up all the way and the belt goes floppy.
Just don't slip off as it can really hurt your hand.
If you are dojng it alone, then best to prop the tensioner open with a little drill bit/allen key L, I usually just have a mate assist.
Offline Dale
« Reply #8 on: February 29, 2016, 08:42:14 pm »
Nice one cheers bud.
Offline Dale
« Reply #9 on: March 05, 2016, 11:20:34 am »
You were right, just checked this morning and I think it's the alternator.  (Turns both ways)
Offline skard
  • -Receive: 245
« Reply #10 on: March 05, 2016, 11:21:53 am »
GSF car parts sell the INA pulley that VW use, for a lot less too
Offline Dale
« Reply #11 on: March 05, 2016, 01:17:01 pm »
Ok cheers.
Offline ALIAHMET
« Reply #12 on: March 09, 2016, 11:01:30 am »
What about the tension arm
Is it suppose to bounce? as I checked mine and its bouncing up and down....
Offline Dale
« Reply #13 on: March 09, 2016, 09:12:13 pm »
Don't think it should be bouncing up and down?
I checked the alternator again using the video and I'm pretty sure it's ok.
Went to vw and bought a new tensioner so I'll try that first and report back.
