Author Topic: Engine swap guide needed  (Read 8341 times)
Offline Markis236
  • If in dout boost it out !
  • My Ride: Mk5 golf gti (ko3) mods. Audi s3 8p intercooler,psi tuning 2.5' throttle pipe,updated diverted valve,revo oil catch can
« on: April 29, 2016, 11:34:07 am »
Any one got a guide on how to do and angina change / swap in the mk5 golf gti ? Doing one Saturday and need my baby up and running by Monday so would be handy to have a guide to go by
Offline Paradox1
  • -Given: 41
Re: Engine swap guide needed
« Reply #1 on: April 29, 2016, 01:50:34 pm »
Id imagine its the same as taking out any fwd engine.
If you haven't done it before I would try it out hoping for the best unless you know exactly what your doing. its not simple like fitting an induction kit lol
Offline Ricky123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« Reply #2 on: April 30, 2016, 01:38:20 am »
You'll be lucky to get it done in a day. Leave the gearbox in, the mounts will hold it fine. Remove the full front end off the car too.
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline Markis236
« Reply #3 on: April 30, 2016, 07:37:50 am »
Iv changed an engine before in my mk2 but eats the best way to do it ? Take the complete front end out and try lift the hole unit out in one ?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: April 30, 2016, 01:37:43 pm »
Front end off front wheels off unbolt drive shafts from inner I think 12 sided spline bit. battery tray out gear box and engine mounts off. lower dog mount off. all ancillaries unplugged where necessary. gear links off if taking it out with engine or your choice whether to leave in.
Fuel lines off
all radiator hoses front and rear of engine off. air con can swing outward without taking pipes off I think so you'll have to check.
anything I've missed?.
Offline Markis236
« Reply #5 on: May 01, 2016, 11:38:59 am »
Well that's the new engine and and running like a dream done in 10 hours hahah
« Reply #6 on: May 01, 2016, 12:24:41 pm »
That is good going Mark
Offline GTI8v
« Reply #7 on: May 01, 2016, 03:46:08 pm »
Well done!  :congrats:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: May 01, 2016, 05:50:20 pm »
10 hours  :happy2:
Offline doylebros
« Reply #9 on: May 01, 2016, 06:22:39 pm »
Well done, you'll have to share your knowledge of how you completed your feat, including your facility and tooling (outside on your drive or access to hoist and engine crane etc).
Not forgetting how many helpers you had access too, as other may be lulled into a false sense of security on such a task.
« Last Edit: May 01, 2016, 06:24:15 pm by doylebros »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: May 01, 2016, 06:31:42 pm »
One man could do that job but not so quick if it's the first time and on the floor.
It took me 6 hours to take a renault 5 gt turbo engine out on my own and it was a dark garage with poor lighting hoist on RSJ.
Offline Markis236
« Reply #11 on: May 02, 2016, 09:27:15 am »
Well I have access to a clean dry shed with heating and a nice car ramp witch makes a hell of a difrence and a engine crane so I could just hold the engine and lifted the car off the engine and slid the hole unit out in one go and after I had the engine out I got 2 helpers and we just cracked on with changing some hoses some sensors and just fired it back in ! The the only pointer I would give is mark all the plugs and wires you disconnect! Was stuck here as I never -.-
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: May 02, 2016, 10:45:44 am »
See that's what makes me think it's impossible to do it in that time no prejudice toward you at all here.
All the ancillaries to remove and refit takes time and the wiring back to the car and we all forget where certain wires were. even me  :doh:
Anyways glad you've got it done however long or short it took you  :congrats: :driver:
Offline Markis236
« Reply #13 on: May 02, 2016, 03:32:55 pm »
The engine I bought had all the sh*t still bolted to it ! It was just a simple pull the AXX sh*t OUT change a couple hoses and pipes and through the BWA in and connect all the wires up and bleed the clutch
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: May 02, 2016, 06:05:44 pm »
Lucky to get all the ancillaries with it as a lot of people sell those bits separately to aquire more monies  :signLOL:
I've sold three renault turbo engines I had laying around in the garden and left it all complete ready to chuck in bar the turbo chargers. so yes well done and hope it's running well?.
