Author Topic: speed bleeders  (Read 3784 times)
4ndy
speed bleeders
« on: May 08, 2016, 07:00:03 pm »
Offline th3_f15t
  • -Receive: 183
Re: speed bleeders
« Reply #1 on: May 08, 2016, 07:06:12 pm »
Looks OK, but to be honest with you an OE valve is just fine for most cars. The bit about letting air in is a little bit over exaggerated, likely based of a theory with no real world proof...
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=acvmkfmecok2ncuacq70jb0d5n&/topic,19740.0.html
Re: speed bleeders
« Reply #2 on: May 08, 2016, 07:15:12 pm »
I am gonna get one for my next service. Hot oil pissing out at 100mph is annoying and messy.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: speed bleeders
« Reply #3 on: May 08, 2016, 09:35:08 pm »
When's your next service rich and will ypu be doing a review  :happy2:
Re: speed bleeders
« Reply #4 on: May 08, 2016, 09:58:31 pm »
4000 miles
Offline Octoparrot
  • -Receive: 104
Re: speed bleeders
« Reply #5 on: May 08, 2016, 10:15:07 pm »
I had these fitted to my previous car (non Vag) and they worked very well, made one man brake bleeding a doddle, not cheap though, I think a full set cost me over £100 and you have To pay extra for the protective caps, but I would consider fitting another set to the golf.
Re: speed bleeders
« Reply #6 on: May 08, 2016, 10:20:10 pm »
OP is referring to the oil sump plug valve
Re: speed bleeders
« Reply #7 on: May 08, 2016, 10:24:42 pm »
I think :thinking:
Offline Octoparrot
  • -Receive: 104
Re: speed bleeders
« Reply #8 on: May 08, 2016, 10:35:41 pm »
No I fitted the brake bleeders as well as I always liked to know my brakes were bled thoroughly and I never really trusted garages to do them. I do also really recommend the oil drain valve as well though if you do your own oil changes as it makes it so quick and clean and prevents you accidentally stripping the sump plug thread through over tightening.  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: speed bleeders
« Reply #9 on: May 08, 2016, 11:03:32 pm »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: speed bleeders
« Reply #10 on: May 08, 2016, 11:05:03 pm »
I read the description and you have to pay extra for the valves so I won't bother  :signLOL:
