All Things Mk5 > How to Guides / Troubleshooting
Problem with G85 / clock spring after MFSW retrofit
<< < (5/5)
SI-R32:
If I were you I would just buy a cheap 1K0959654 from ebay fit it and see if it works, this should 100% work with the CH module
supercati:
--- Quote from: r5gtt on June 12, 2016, 05:03:21 pm ---Maybe a faultt CH ?
All wheel have sensor on them so bearing broken will not pick up a signal from this.
If you have a slot to fit steering sensor then maybe get one and see if that helps although I couldn't be sure it will but worth a try.  :smiley:
--- End quote ---
I thought also about faulty CH... (It was brand new).
--- Quote from: SI-R32 on June 12, 2016, 05:14:19 pm ---If I were you I would just buy a cheap 1K0959654 from ebay fit it and see if it works, this should 100% work with the CH module
--- End quote ---
Seems good option guys, I'm gonna go for that. I have one near here for 15€, it's worth to give it a try (maybe the CH needs this steering angle sensor).
If then it works... perfect!!  :grin:
If then it doesn't work... :scared: Next step will be fix wheel-bearing (which I need to do anyway).
I will keep you updated guys with the result and future inputs!
r5gtt:
Yes do let us know and good luck  :happy2:
supercati:
Here I am again @r5gtt @SI-R32 and other readers.
So... first a picture.
I bought the steering wheel angle sensor which my car didn't had before. Install it (reaaaally easy), and then I did the basic setup as follows here:
1- http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1J)_Brake_Electronics_(MK60)#Basic_Setting (it showed error on VagCom Basic Setting and degrees didn't change from 0'00º. But I did it anyway).
2- http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation following the 1st step, just the VCDS thing without doing anything more.
3- http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation
After step 3 errors didn't turn off.
I did again the procedure:
1- http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1J)_Brake_Electronics_(MK60)#Basic_Setting and as soon as I started driving forward because is what it says there... ESP/ABS error went OFF!
2- http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation and steering assist error went off! :D
So now everything is in order guys. The steering assist seems to be maybe softer than before...
That's what I had installed: 1K0959654
r5gtt:
Congratulations  :congrats: you finally have it sorted now  :smiley:
Yes you have drive forward to calibrate the SAS in order for the errors to deleye off the screen which is what I did with my tt so all good.
Thanks for updating us on this as it must have picked your brain  :stupid: somewhat but now all okay  :grin:
Good one for the part no too.  :happy2:
R5
Navigation
[0] Message Index
[*] Previous page
Go to full version
