Author Topic: What side is REAR RIGHT ?  (Read 2507 times)
80walk
« on: August 02, 2016, 08:45:44 am »
abs, esp and tyre pressure light all on dash ... scanned and code 00287 comes up
00287 - ABS Wheel Speed Sensor Rear Right (G44)
stupid question but which side is rear right ? ... is it as you stand looking at the engine or standing at the rear of the car ?
Gonna try new sensor first at £15.
thanks.
Offline bad devotions
  • -Given: 19
Re: What side is REAR RIGHT ?
« Reply #1 on: August 02, 2016, 09:11:08 am »
thanks.
IMO that would be offside rear. if you were sat in the car the right would be to your right.
80walk
« Reply #2 on: August 02, 2016, 09:13:37 am »
thanks for reply.
Do all wheels have ABS wheel speed sensors ?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #3 on: August 02, 2016, 09:40:59 am »
Yes they do
80walk
Re: What side is REAR RIGHT ? (Disaster)
« Reply #4 on: August 07, 2016, 01:11:50 pm »
Disaster ... When I tried to remove old sensor it was so badly rusted in and I managed to break the damn thing off in the process ... ! So probe is stuck in there now ... What Options have i got now !?
Offline Chris92
  • -Given: 33
« Reply #5 on: August 07, 2016, 01:15:57 pm »
It's just plastic I'd just use a small punch or screw driver and a hammer then smash it up, maybe the magnetic ring on the back of the bearing either
80walk
« Reply #6 on: August 07, 2016, 02:03:26 pm »
Thanks ... Get ur idea of a punch and hammer but is it ok to push it through into the housing ?
Offline Chris92
  • -Given: 33
« Reply #7 on: August 07, 2016, 02:20:28 pm »
Done it loads no problem, it should just fall out unless the driveshaft stops it. May need to remove bottom ball joint and hub nut to allow the shaft to open a space up
80walk
« Reply #8 on: August 08, 2016, 12:25:32 pm »
this has happened on the rear right ... if i were to punch it out or drill it our from the inner side of the car isn't it a prob if the left over bits of the sensor are pushed inside the hub of the wheel ... ??
