Author Topic: Led side light keeps blowing?  (Read 2895 times)
Offline kam
« on: September 18, 2016, 08:52:39 pm »
Can anyone shed some light I have Led side lights fitted to Xenon lights the O/S light which is a genuine new unit keeps blowing the bulb every two to three months any ideas why and why only the O/S thank you .
Offline kam
Re: Led side light keeps blowing?
« Reply #1 on: January 02, 2017, 04:20:00 pm »
Bump
Offline Shamm
« Reply #2 on: January 02, 2017, 05:02:23 pm »
Have you checked what amp fuse you have
Offline kam
« Reply #3 on: January 02, 2017, 11:03:41 pm »
Thanks for the reply I havnt checked could anyone confirm which is the fuse for the side lights and the exact location please
Offline kam
« Reply #4 on: January 04, 2017, 09:29:31 am »
Vehicles is a 2005 f47 &f48 spaces are empty could any one confirm location and fuse no please
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #5 on: January 04, 2017, 09:32:27 am »
Any moisture getting into the light? It is quite common to see. Remove the light and check if there is any moisture around the connection. If there is you'll need to seal it.
You do have the plastic cap on the back of the sidelight yes?
Offline kam
« Reply #6 on: January 04, 2017, 12:55:38 pm »
Luke the light is around a year old bought new from vw it has the rubber cover over the light doesn't appear to be any moisture around the fitting.
Offline mrw
« Reply #7 on: January 04, 2017, 08:11:54 pm »
What bulb's are you fitting?
Offline kam
« Reply #8 on: January 05, 2017, 06:46:11 am »
Lund are some sort of Chinese units supplied from Matt from this forum
