Author Topic: Interior Lights Not Working On Unlock  (Read 10973 times)
Offline loudancoe
« on: September 21, 2016, 11:09:34 am »
When I unlock the car, the front and rear interior lights don't come on but the footwell lights do. The selector switch is in the door open position, and they work when I use the switch to turn them on manually.
Any ideas on what might be going on here?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Interior Lights Not Working On Unlock
« Reply #1 on: September 21, 2016, 12:24:08 pm »
Check all the plugs in the CECM are properly plugged in, Had this once after I took a plug out the CECM to add heated seats but didnt click it in properly
Offline loudancoe
« Reply #2 on: September 21, 2016, 12:31:32 pm »
Thanks ill give that a try
Offline lukemk5gti
  • -Given: 28
  • -Receive: 119
« Reply #3 on: September 21, 2016, 01:52:11 pm »
Blew a fuse? Seems strange that all 6 bulbs between the front and rear of the car all went simultaneously.
Offline loudancoe
« Reply #4 on: September 21, 2016, 02:05:29 pm »
They still work when i use the manual switch on the roof its just when i unlock the car/open the door they dont come on
Offline lukemk5gti
  • -Given: 28
  • -Receive: 119
« Reply #5 on: September 21, 2016, 02:24:08 pm »
Do you have highline clocks?
If so, go into convenience mode on your settings. You probably turned them off when opening the door and unlocking.
Offline loudancoe
« Reply #6 on: September 21, 2016, 02:26:25 pm »
If you mean what i think, as in the screen on the dash i only have the standard one that doesnt have any menus
Offline lukemk5gti
  • -Given: 28
  • -Receive: 119
« Reply #7 on: September 21, 2016, 02:30:53 pm »
In that case you'll need VCDS.
Sounds like someone has turned off convenience mode on your lights for auto on/off when door opens/closes.
Offline loudancoe
« Reply #8 on: September 21, 2016, 02:33:49 pm »
I thought that might be the case but when i bought the car it was completely stock from a middle-aged woman who I can't really see her with vcds
Offline lukemk5gti
  • -Given: 28
  • -Receive: 119
« Reply #9 on: September 21, 2016, 02:40:51 pm »
Sounds strange alright but it could have been someone before her or even a relative. Maybe she kept leaving the lights on and flattened the battery in the past so someone could have disabled them for her.. You never know the past history.
That's where I would start anyway.
Google highline vs midline clocks just to double check what you have
Offline loudancoe
« Reply #10 on: September 21, 2016, 02:45:48 pm »
True she was the only owner but as you say someone may have done it for her. Yeah definitely midline clock. Now i just need to get VCDS  :confused:
Offline vwpete91
« Reply #11 on: December 11, 2016, 04:43:58 pm »
Try removing the convienence light module at the front and check that the spring on the buttons is not offset I fixed this problem with my mk5 as the spring pushed to the side and needed readjusting hope this helps
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #12 on: January 05, 2017, 08:07:14 pm »
When you say module, you mean the bit around the light or the whole thing in the roof as I've got the same thing.
