Author Topic: Installing FW to rns 510  (Read 1887 times)
« on: January 21, 2010, 06:17:11 pm »
Never had a problem with this in the past but I can't seem to install 2680 to my unit.
I put the disc in and it does nothing. I've burned 3 discs now at the slowest speed, all say they're burnt fine.
So I thought I'd go to fw 1200 and try that way. The only was I can get it to even think about installing is using eject setup and info buttons.
Strange one. Any ideas?
Re: Installing FW to rns 510
« Reply #1 on: January 21, 2010, 06:24:28 pm »
What's your procedure?
This is what I did:
 - open car using key
 - get into car and close door
 - don't insert key into ignition
 - make sure it's on FM radio
 - slip disc into unit
 - reboot the unit
 - let it automatically start up
Just outta curiosity, did you verify the discs once burned?
« Last Edit: January 21, 2010, 06:26:04 pm by stealthwolf »
« Reply #2 on: January 21, 2010, 06:26:58 pm »
Just remembered, you have to enable downgrade option. Can't remember how though.
« Reply #3 on: January 21, 2010, 06:49:06 pm »
My procedure is pretty much same as yours mate. :(
Offline QD MBE
  • -Receive: 102
« Reply #4 on: January 21, 2010, 06:52:38 pm »
Jay,
i have a 2680 disc that i used on mine, so I know it works, I can send it to you to try?
« Reply #5 on: January 21, 2010, 07:42:44 pm »
I've got darren sending me one so wouldn't want to deprive anyone else of a disc. Feel tight enough darren (mortytdi) sending me one haha
