August 28, 2025, 11:43:39 am
All Things Mk5
How to Guides / Troubleshooting
caliper carrier bolts....
Topic: caliper carrier bolts.... (Read 5106 times)
AndrewWillis
Always Involved
-Given: 3
-Receive: 5
September 30, 2016, 12:31:32 pm »
I'm trying to swap my discs and pads, but I cannot get the two carrier bolts out, they've been soaking in WD for about and hour but they're still solid, any suggestions?
05, 3door Red GTI DSG, BCS Powervalve 200 Cell, DNX525DAB, Xenons, R-Tech 2+
v4rley
Just look at my post count
-Given: 29
-Receive: 104
Re: caliper carrier bolts....
Reply #1 on:
September 30, 2016, 12:42:59 pm »
Front or rear? What tools you using?
AndrewWillis
Always Involved
-Given: 3
-Receive: 5
Reply #2 on:
September 30, 2016, 12:44:17 pm »
Fronts, I have a 21mm, 1/2 inch socket on it at the moment, -as that's all I have access to.
v4rley
-Given: 29
-Receive: 104
Reply #3 on:
September 30, 2016, 12:45:36 pm »
What length bar?
AndrewWillis
Always Involved
-Given: 3
-Receive: 5
Reply #4 on:
September 30, 2016, 12:46:38 pm »
18" breaker bar
Pesky jones
-Given: 2
-Receive: 19
Reply #5 on:
September 30, 2016, 12:49:41 pm »
I stuggled with this - don't you need an m14 or an m16 for the caliper carrier bolts?
I think a 600mm breaker bar is perfect if working off the ground, any longer and you'll hit the ground with the bar. My 900mm bar would just about to start to take the stress before hitting the ground. Obviously the higher you can get the car the better
v4rley
-Given: 29
-Receive: 104
Reply #6 on:
September 30, 2016, 12:51:07 pm »
Would have though that be enough to crack them. Only other ideas I would have is trying to extend the leverage or applying some heat. Stupid idea but guess your going the right way
M14 is for the rears
AndrewWillis
Always Involved
-Given: 3
-Receive: 5
Reply #7 on:
September 30, 2016, 12:53:05 pm »
They've never been off before and the car is coming up to 12 years old now, so they must be pretty well seized on, I really struggle with the Allen bolts, but finally managed those ones, I might have to just suck it up and take it somewhere
Flyingscotsman
Always Involved
-Given: 26
-Receive: 23
Reply #8 on:
October 02, 2016, 07:36:45 pm »
Got mine off with a breaker bar - wasn't too bad. Not sure length of my bar but think its a bit longer than 18 '' maybe 24 ".
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #9 on:
October 02, 2016, 07:47:48 pm »
Put on the socket and ratchet and whack it with a mallet! Worked when I did my rears.
https://www.justgiving.com/thenational3peaks
AndrewWillis
Always Involved
-Given: 3
-Receive: 5
Reply #10 on:
October 08, 2016, 11:56:26 am »
Ended up having to use an impact socket to get them shifted, they certainly did not want to move! At least now I have some decent pads and discs for the stage 2+ that I'm now running!
All Things Mk5
