September 10, 2025, 10:57:26 am
All Things Mk5
How to Guides / Troubleshooting
Car cut out
Topic: Car cut out (Read 2103 times)
AlexRennieGti
Just Arrived
-Given: 0
-Receive: 0
Car cut out
March 26, 2019, 09:14:42 pm »
Hey guys driving home tonight and my car cut out. No warning lights or anything. Tried too start it again and it seemed as if the battery was dying. But after a few turns of the key it started and ran fine.
Anyone got any ideas ?
Alex Booth
Taking part
-Given: 1
-Receive: 7
AKS Tuning
Re: Car cut out
Reply #1 on:
March 27, 2019, 03:02:00 pm »
Do you have access to VCDS? Could be a number of things.
AlexRennieGti
Just Arrived
-Given: 0
-Receive: 0
Re: Car cut out
Reply #2 on:
March 27, 2019, 03:50:02 pm »
Yes I do. Done a quick scan and no faults shown up
muff1991
Won't Shut up.
-Given: 8
-Receive: 70
Re: Car cut out
Reply #3 on:
March 27, 2019, 04:25:57 pm »
have you had any work done recently? put a multi meter on your battery before starting then again once started.. see what volts you're getting.
has the car started and drove fine today?
AlexRennieGti
Just Arrived
-Given: 0
-Receive: 0
Re: Car cut out
Reply #4 on:
March 27, 2019, 07:40:55 pm »
Before starting voltage was 11.5v and once running voltage was between 13.9-14.3v
The car smells like it’s over fueling can smell petrol
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 691
Re: Car cut out
Reply #5 on:
March 29, 2019, 01:23:04 pm »
Cut out under what circumstance? Driving along normally, or when pulling up to a junction/roundabout?
11.5V is too low. Should be around 12.6 with the engine off, so you'll be needing a new battery at some point.
AlexRennieGti
Just Arrived
-Given: 0
-Receive: 0
Re: Car cut out
Reply #6 on:
March 31, 2019, 08:07:50 pm »
I would honestly be better with a new car. More problems today.
While driving getting random puffs of smoke from exhaust not constant and get low oil pressure flashing up flashes like once or twice and goes off.
muff1991
Won't Shut up.
-Given: 8
-Receive: 70
Re: Car cut out
Reply #7 on:
April 01, 2019, 08:58:51 am »
maybe it could be the Oil Pick Up Pipe in the sump?
AlexRennieGti
Just Arrived
-Given: 0
-Receive: 0
Re: Car cut out
Reply #8 on:
April 01, 2019, 11:06:18 am »
Would that cause the odd puff of smoke but ?
muff1991
Won't Shut up.
-Given: 8
-Receive: 70
Re: Car cut out
Reply #9 on:
April 01, 2019, 03:20:00 pm »
not sure if it would be the cause of smoke but it could be the cause of the low oil pressure
All Things Mk5
Car cut out
