Author Topic: Brake pads for track days  (Read 9806 times)
Offline Bogdanbd
Re: Brake pads for track days
« Reply #15 on: March 25, 2010, 11:00:12 pm »
I'll be with Fuscobal at the Ring too.
Since is my first time on the Ring for and I will not drive like "crazy" to squeeze everything out of the car I decided to go for Hawk HP+ pads.
I hope they are a good compromise, I will be using them also on the road to the Ring and back.
I was also thinking abt CT XP8, but after I found out that the rotors they will be installed on can not be used with other pads I've given up on them. Too much additional cost.
4x4-O2 RS REVO stg 3 - 370HP-K04 turbo-Haldex controller-Autotech HPFP-S3 injectors-NGK sparks-RS4 FPR Valve-EVOMS CAI-S3 FMIC+Forge Twintercooler & Actuator-USP fluidampr-custom 3" Magnaflow exhaust-KW coilover kit V1-S3 brakes front/rear + TAROX F2000 discs-LOBA-Sachs stg 2-VF Mounts-BSH PCV revamp-Forge short shifter-W.A.L.K.-H&R AntiRollBar kit + BSH end links -Team Dynamics ProRace 1.21 8x8J Anthracite/White
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #16 on: January 12, 2013, 09:39:39 pm »
Seems Volkswagen Racing Poland uses Pagid RS4-4:
"You get what you pay for."
Offline fuscobal
« Reply #17 on: January 13, 2013, 01:11:39 am »
Same brakes as me I guess :) Any closer pics to the rear wing ?
Mk5 GTI 6MT - Revo stage 3
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Offline fuscobal
« Reply #19 on: January 13, 2013, 09:29:25 am »
Very nice, thanks. Sounds like about the same length as mine but larger chord (225 I'd say)
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #20 on: January 13, 2013, 09:50:14 am »
Where did you get this info from?
 :drinking:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #21 on: January 14, 2013, 12:07:31 pm »
There aren't many true racing pads colored like these:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #22 on: January 14, 2013, 12:28:03 pm »
Yup... they looked red from the other photos.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #23 on: March 18, 2013, 04:56:12 pm »
Some time ago APR was selling these awesome (I guess) "Performance Friction" two-piece rotors
if I remember correctly and still use them on their GTI race cars with stock calipers (due to rules I bet).
They are stock size 312 x 25 mm and would be a nice match for Boxster calipers.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #24 on: March 18, 2013, 05:55:02 pm »
1. These are drilled and I am not sure they won't crack.
2. I guess they are 2 piece rotors but not floating.
3. Tarox can also make 2 piece rotors 312x25 (any types of groves) but they cost ~ 700 EURO/pair.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #25 on: March 18, 2013, 06:36:42 pm »
Yes, I know Tarox make some with the rotor you like. They even make a complete
312 x 25 6-pot BBK.
These Performance Friction aren't drilled though, just ''dimpled''. PF does it on many
'Direct Drive' kits.
Believe me, they are even better than Tarox. No need to talk about prices. If they
would still make them, I'd bet they were close to 1000,-- €.
 :confused:
BTW, I'd bet these discs are "Direct-Drive" (truely floating), but no safe information
currently available.
« Last Edit: March 19, 2013, 01:46:29 am by the bruce »
