Author Topic: Ed30 APR Stage2  (Read 7275 times)
Offline khz30
  • Gti Edition 30
  • My Ride: MK5 Edition 30
Ed30 APR Stage2
« on: March 27, 2021, 01:55:09 am »
New Member, New Purchase...
Edition 30..
Opinions? It’s running on APR Stage 2. Is it worth taking it to R-Tech to get it checked over?
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,131272.0.html
Re: Ed30 APR Stage2
« Reply #1 on: March 27, 2021, 08:56:52 am »
Looks like a pretty cool example  :happy2:
You can do if you like, I would say unnecessary personally but it won't hurt if you want some specialists opinion. Alternatively there is loads of information on common faults engine wise e.g pcv, cam follower,  diverter valve etc. And how to guides to check and fix/maintain yourself.
Offline khz30
  • Gti Edition 30
Re: Ed30 APR Stage2
« Reply #2 on: March 28, 2021, 12:55:28 am »
Cheers mate. I think I’ll give R-Tech a miss at the moment. Yeh, the common faults etc is cool.
Offline LC5F
  • -Receive: 80
Re: Ed30 APR Stage2
« Reply #3 on: March 28, 2021, 11:58:42 am »
Clean Golf - looks like a lot has been done to this.
Maybe take the time to check what its got - from the 2 pictures I can see its already got Mk7 R calipers, poly engine mounts, what else is there underneath?
Offline khz30
  • Gti Edition 30
Re: Ed30 APR Stage2
« Reply #4 on: March 29, 2021, 02:48:50 am »
Yes your right..it’s got the 4 pot Audi TTS brakes setup. It did have a power flex back box delete along with the catless downpipe but was way too loud for me so I’ve reverted to the original back box with the downpipe. Sounds way better now lol.
*Spec:*
Direnza aluminium alloy FMIC Intercooler.
Vis motorsport HPFP internals.
Ram Air Oversized induction kit.
WG short shifter.
R8 coil packs.
Ngk BKR7EIX iridium spark plugs.
Darkside development Gearbox shim kit fitted.
Revo engine / gearbox & dog bone mount.
Power flex anti lift kit.
New subframe bolts.
New OEM diverter valve & PCV.
New dip stick.
New battery.
H&R coilovers.
Upgraded Sachs performance clutch and LUK flywheel.
New OEM master cylinder.
New Top temp sensor.
New Brembo Audi TTS 340mm front brake discs / pads and heat shields.
Recently had an S3 8p big brake upgrade.
'Hel' carbo look R32 braided hoses.
After market arm rest/storage compartment. Upgraded Andriod head unit.
Pioneer 600W front and rear speaker upgrade.
All wired up ready for a sub.
Depo R32 style headlights.
Xenon 6000k HID kit.
Carbon fibre mirror caps.
Front and rear aero blade wipers
Recently had a full detail / machine polish.
Audi stlye LED wing mirror indicators.
LED number plate lights.
LED Interior lights.
Gloss black front and rear badges.
New front grill/fog light covers.
Carbon fiber headlight eyelids.
3" catless downpipe.
Heko front wind deflectors
Aftermarket stubby aerial.
35% tints all round.
Maxton Design rear spoiler lip
Carbon fibre effect hydro dipped rims.
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
Re: Ed30 APR Stage2
« Reply #5 on: March 29, 2021, 03:51:52 pm »
Welcome mate.
Car looks very clean!
Got a good spec too.
Any particular reason you want the car checked over?
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
Instagrams;
@shannon_ob
@dinger_developments
Offline LC5F
  • -Receive: 80
Re: Ed30 APR Stage2
« Reply #6 on: March 29, 2021, 05:05:32 pm »
WG short shifter.
R8 coil packs.
New subframe bolts.
New dip stick.
New battery.
H&R coilovers.
Ah - 4 pots great - Good to see its had a couple of supporting mods done!
Did the PO run out of mods and get bored?
Offline FatWelshBoy
Re: Ed30 APR Stage2
« Reply #7 on: March 30, 2021, 10:08:39 am »
Car looks great. I'd recommend going to R-Tech for a once over and possibly a remap. I had APR software on my Ed30 and it made a load of power for stage 1, 321 bhp and 360 ft-lbs, but was found to be running a bit too lean for comfort. The main reason for changing to R-Tech software was the throttle mapping, it was like an on/off switch. The R-Tech remap makes 302 bhp and 325 ft-lbs but its far nicer to drive and the linear throttle mapping is superb, suppose that's the benefit of a custom remap over a flash remap.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
Re: Ed30 APR Stage2
« Reply #8 on: March 30, 2021, 11:05:58 am »
Looks like a very well modified example. How does it drive?
Offline khz30
  • Gti Edition 30
Re: Ed30 APR Stage2
« Reply #9 on: March 31, 2021, 10:51:56 am »
Welcome mate.
Cheers mate. Just thought R-Tech are better than APR?
Offline khz30
  • Gti Edition 30
Re: Ed30 APR Stage2
« Reply #10 on: March 31, 2021, 10:54:03 am »
The previous owner ended up buying a e46 M3 which was his dream car and wanted to get rid of this. I think he got bored of all the mods. Lol.
It drives well, although the clutch pedal can stay down and I have to flick it with my foot. Not a issue but I was told maybe there’s some air stuck and needs bleeding? Also, they’re very tappety on cold start?
Offline shannon-ob
Re: Ed30 APR Stage2
« Reply #11 on: March 31, 2021, 11:36:03 am »
Can't say I blame him, I'd sell my Golf for E46 M3 all day.
Yeah, I'd look at getting that bled through mate, not nice to try and drive like that!
They are very tappy engines at anytime mate, the injectors are noisy and the cam follower. Perhaps have a new cam follower fitted as a piece of mind, and maybe a service. Unless there's history showing it's been done recently.
Instagrams;
@shannon_ob
Offline khz30
  • Gti Edition 30
Re: Ed30 APR Stage2
« Reply #12 on: March 31, 2021, 02:43:18 pm »
Your right..will get it checked in the next week or so. The Cam follower was changed at 72000, mileage now is at 84000. It was only serviced 3000 miles ago but will get another one done in the next couple of months too. What do you think?
Offline muff1991
  • -Receive: 70
Re: Ed30 APR Stage2
« Reply #13 on: March 31, 2021, 06:39:03 pm »
Nice car and plenty of stuff done to it. I don’t want to scare you, but when the clutch sticks down and you’re having to pull it up with your foot usually means there’s a leak or air in the system! (If there’s a leak you could be sucking air in) It may just need a bleed but when I had this exact same issue, it became more regular, all of a sudden when parking up at work the master cylinder popped and fluid was everywhere lol.
I’d bleed it, see how you get on, but keep an eye on it. You don’t want to be stranded somewhere.
Offline Dizzi
Re: Ed30 APR Stage2
« Reply #14 on: March 31, 2021, 10:01:37 pm »
Looks a very clean example this and seems to have been looked after.
I always service my cars right after buying them just for peace of mind. Probably worth changing the cam follower, i've heard of guys getting bad wear after just 10k miles and others lasting up to 20k miles so since it's cheap and easy to replace id say its worthwhile for peace of mind again.
