Author Topic: ***update*** Dashboard warning lights?  (Read 11122 times)
Offline blingsta
« on: November 14, 2021, 11:34:49 am »
Hi all,
This has happened on a few occasions now, just wondering what it's trying to tell me  :signLOL:
https://i.imgur.com/huVzR6N.jpg
The lights stay on fir a little bit and then go off?
« Last Edit: November 21, 2021, 06:50:12 am by blingsta »
Offline LC5F
  • -Receive: 80
Re: Dashboard warning lights?
« Reply #1 on: November 14, 2021, 12:24:01 pm »
Mine has been doing that since tweaking the wiring to the ABS sensor - I was pulling myself up from under the engine, grabbed onto what I thought was the caliper but missed, pulling on the cable.
It was coming up all the time, but seems to have settled itself down - last time it came up was a month ago from wheel spinning/axle hop.
Offline blingsta
« Reply #2 on: November 14, 2021, 12:40:45 pm »
Hmmm  :thinking:
Last thing I remember doing was using the jetwash at work to clean my wheels.  I'll see how it goes for now and hope they don't stay longer
Offline blingsta
« Reply #3 on: November 14, 2021, 12:41:26 pm »
Thanks for the reply BTW 👍
Offline jacksosi
« Reply #4 on: November 14, 2021, 11:41:32 pm »
We had exactly that set of lights, turned out to be the battery was past its best. Replaced it and it’s cleared the issue
My post from another thread…
Replaced the battery, it still had the original !
We had been getting frequent dashboard lights at startup (PowerSteering, ESP, Tyre Pressure) that would go away after a few minutes. Had it checked but no fault codes, mentioned that the electric windows were a bit slow to respond and he also noticed the ignition sounded sightly laboured, checked under the hood and advised that it was worth changing the battery as that could be the source of the issues.
Stuck with Varta as the original had been so good, got a slightly higher spec replacement for £81 delivered.
https://www.tayna.co.uk/car-batteries/varta/e44/
« Last Edit: November 14, 2021, 11:43:47 pm by jacksosi »
Black MkV Gti (Nov 2008), no modifications
Offline blingsta
« Reply #5 on: November 15, 2021, 12:51:15 am »
^^^ thanks for that matey  :happy2:
i'll keep a close eye on things, cold weather is around the corner so i'd rather replace it sooner rather than later..
Offline blingsta
« Reply #6 on: November 15, 2021, 04:00:05 am »
just a quick update.. the lights are constantly on now  :scared:, but ive got no other issues like longer cranking or windows slowing down etc ? and no faults logged
Offline FJB
« Reply #7 on: November 15, 2021, 04:10:53 am »
You will not know the exact cause until you get it scanned, but it is likely to be either a wheel bearing or abs sensor fault.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline jacksosi
« Reply #8 on: November 15, 2021, 06:33:22 am »
As I mentioned above, we didn’t have any fault codes either. The other two symptoms were almost imperceptible, the window button would be deactivated for maybe a couple of seconds after ignition but after that would work like normal.
That may not happen with yours , but it’s worth checking the battery age, if it’s old/the original then it’s worth changing as it’s fairly low cost and it fixed it for us…was pretty relieved the mechanic spotted it as I couldn’t find anything from Googling the issue.
Offline blingsta
« Reply #9 on: November 15, 2021, 08:40:51 am »
Thanks for the replies guys... I'll look into getting it sorted asap
Offline blingsta
« Reply #10 on: November 20, 2021, 08:39:37 am »
well chaps !!!   ive been driving the car with them dash lights on for a few days and thought nothing much of it..   i had 4 days off and must have used the car once..  woke up for work this morning and.......   car is dead  :confused:, even the doors wouldnt open with the fob..   so it looks like i have to buy a new battery today  :fighting:
Offline jacksosi
« Reply #11 on: November 20, 2021, 11:21:07 am »
If only someone had posted a solution
Hope you get it sorted
« Last Edit: November 20, 2021, 11:32:39 am by jacksosi »
Offline blingsta
« Reply #12 on: November 20, 2021, 11:36:34 am »
Lol mate..   thanks for all the input..    i'll be leaving work early today, straight to Euro's for a new battery.  if all the warning lights go off after the new battery then thats a bonus, if not....   i'll get her booked in for a scan and new sensors/wheel bearings..  :happy2: :grin:
Offline LC5F
  • -Receive: 80
« Reply #13 on: November 20, 2021, 11:47:00 am »
Interesting - before getting replacement just check the voltage on the old battery, should be around 12.5v.
Mine would play dead with a brand new battery, sometimes completely dead, other times it would pop the doors but then not start - acted like a dead battery, it would even loose window memory - disconnecting and reconnecting the battery would usually bring it back to life.
Eventually found it was terminal 15 relay under the steering column gone bad, I have not had any issues since.
Offline blingsta
« Reply #14 on: November 20, 2021, 12:15:50 pm »
ohhh !!  that is interesting,  unfortunately i dont have any means of measuring the battery voltage  :sad1:,  so i might just pop home 1st and disconnect the battery and connect back again to see if anything happens,   i'll also check that relay  :happy2:
« Last Edit: November 20, 2021, 12:17:28 pm by blingsta »
