Author Topic: Oil leak.  (Read 2132 times)
Offline imprezzaworks
Oil leak.
« on: April 03, 2022, 09:57:33 am »
When the guys were doing the tracking they showed me on the drivers side of the car the undetray with oil on. Going to investigate it more this week but any common areas above there?. I'm guessing a weak pipe, hopefully.
Offline LC5F
  • -Receive: 80
Re: Oil leak.
« Reply #1 on: April 03, 2022, 11:38:17 am »
Assuming you have a short undertray, I would think boost pipe seal.
Re: Oil leak.
« Reply #2 on: April 03, 2022, 11:39:12 am »
Will get it up on the ramp tomo. Easy enough to do?
Offline LC5F
  • -Receive: 80
Re: Oil leak.
« Reply #3 on: April 03, 2022, 11:42:12 am »
if it's just the seal its easy, but could be the bayonet fitting working loose from wear, either new same type of hose or upgrade
Re: Oil leak.
« Reply #4 on: April 03, 2022, 11:45:08 am »
Okie dokie cheers.
Will report back tomo
Re: Oil leak.
« Reply #5 on: April 04, 2022, 12:22:41 pm »
Lower boost hose was the issue. A hole in the metal coupling
