Author Topic: traction control light won't go out.  (Read 2816 times)
Offline davidjonknight
« on: November 07, 2022, 02:56:50 pm »
Hello. Apologies if this question has already been asked.
I have a Mk5 Golf Gti without an MOT. It has not had one for some time due to different reasons.
I put in for its MOT on Friday and one of the things it failed on is that the traction control light  wont go off.
It has had the battery disconnected for some time and the error seems to coincide with that.
Doing a scan with OBD11 shows the steering angle sensor at fault .
The steering wheel icon was originally lit, but this is now out after a reset.
Offline Freem82
Re: traction control light won't go out.
« Reply #1 on: November 07, 2022, 04:34:55 pm »
Have you driven it since reset ? It may well go off after a short drive.
« Reply #2 on: November 07, 2022, 04:49:58 pm »
It’s been driven about 2 miles to the mot garage and back
David
Offline MjW
« Reply #3 on: November 08, 2022, 08:24:55 am »
As Freem82 said, give it a good run and it may well reset. There's also a way to recalibrate the system with a laprop/OBD2 lead and various steering inputs done in a certain order. I'm sure there's a link to it somewhere on here.
I would usually say to check front ABS sensor cables as the ABS and TC are linked but this might not be the case as you're not getting ABS warning. Probably worth a look anyway just to rule it out.  :driver:
Offline TheBALDpuma
« Reply #4 on: November 08, 2022, 08:35:46 am »
When I had my battery disconnected to change my plugs the reaction control and steering light came on when I started back up too. It did take a good few miles for them to turn off.
Offline colesey
  • -Receive: 89
« Reply #5 on: November 09, 2022, 06:33:38 pm »
A pre mot fave. Try a few lock to lock turns and a short drive to reset.
Offline Corish
« Reply #6 on: November 13, 2022, 12:02:47 am »
Steering angle needs to see 4 equal speeds from each wheel. I have seen many times the rear right wheel fluctuates in speed and it is nearly always the bearing with the exciter ring.
Go in to 03-ABS and get all 4 wheel speeds up in Measured Value Blocks - 001 and just go in a straight line (don't have to go fast, 5-10mph is fine) and see if they all match, you might find one fluctuates hence why your steering angle fault won't go away.
May be wrong, but seen this many times and nearly always rear right bearing for some reason.
