Author Topic: How to/tips for changing the DV on a K03  (Read 2017 times)
Offline Lewo
« on: November 29, 2022, 10:46:31 pm »
If there's time will try and do this tomorrow.
Any guides about for a K03 or what do I need to do, last changed by Rtech .
Will be on a drive with a trolley jack/stands!
Cheers.
Offline Kierandewberry21
Re: How to/tips for changing the DV on a K03
« Reply #1 on: November 29, 2022, 11:10:13 pm »
Honestly not too difficult, I did it with trolley jack last winter in pitch black with phone torch and pouring down rain, took about 20/30mins. I just watched a couple YouTube videos. Literally 3 bolts 5mm Allen bolts and it’s off if I remember rightly
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,131272.0.html
« Reply #2 on: November 29, 2022, 11:13:14 pm »
As above It's relatively easy, just sometimes fiddly getting to the bolts holding it on. Trick is to get your head behind the wheel hub as you do it that way you can see and reach all the bolts quite easily.
Offline Lewo
« Reply #3 on: November 29, 2022, 11:25:28 pm »
So remove the right wheel, anything else?
I'll have a butchers on YT.
Cheers.
« Reply #4 on: November 30, 2022, 12:31:43 am »
Cheers.
I didn’t remove any wheels
Offline breeze
« Reply #5 on: November 30, 2022, 06:57:55 am »
You don’t even need to remove the wheel arch liner. You should be able to do it based on what you can see/feel. Just make sure the hex head is in securely before you start trying to loosen and ideally replace with new bolts.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #6 on: November 30, 2022, 09:21:50 am »
Yep. I left the wheel on and just can just reach up.
You can just do it by feel once you've had a look at the three bolts to remove.
Offline mjmallia
  • -Receive: 58
« Reply #7 on: November 30, 2022, 12:39:17 pm »
After doing it once I decided to do the K04 relocation.....never looked back
Mike
South Coast
Offline Lewo
« Reply #8 on: November 30, 2022, 06:15:47 pm »
Oh well, my mate tried but couldn't get to one of the bolts so it's still on there lol.
Maybe take it to somewhere that's got a hiost!
Offline akbarirfan
  • -Given: 81
« Reply #9 on: December 04, 2022, 07:58:14 pm »
I took the wheel off, makes it much easier as you don't need to raise the car as much, so have better reach.
Offline OllieVRS
  • -Given: 17
« Reply #10 on: December 05, 2022, 11:11:56 am »
Emphasis on replacing with new bolts - when I was replacing mine the bolts were already damaged from a previous dodgy replacement and I ended up stripping one of them completely, requiring a welder to get it off  :scared:
'06 Skoda Octavia vRS TFSI
Offline Numero9
« Reply #11 on: December 06, 2022, 08:17:44 pm »
I did mine recently on the driveway, using drive on ramps. Didn't take the wheel or liner off. It was manageable but needed just an extra half a foot in height to be comfortably be able to work.
No issues with the access to the part the top bolt you have to work a bit blind I used a 5mm 1/4" hex bit on an 50mm extension, was just the right length. when refitting I hand started 2 to snug to hold the DV in place before fitting the 3rd then tightening.
My bolts looked quite new still as my DV was a Rev G but still failed. Still had threadlock on them and seem okay so far.
Tip for getting the connector off is to push it in whilst pushing the tab down to then get it off.
Offline Lewo
« Reply #12 on: December 06, 2022, 10:17:27 pm »
Cheers, I'll pass info on to my mate and see if he's willing to have another go!
Offline Numero9
« Reply #13 on: December 07, 2022, 08:53:21 pm »
Where are you based? Willing to help if you aren't too far away
Offline Lewo
« Reply #14 on: December 08, 2022, 11:54:41 pm »
Thanks for the offer. I'm in Kent.
