Author Topic: Engine oil overfill  (Read 1726 times)
Offline odav
Engine oil overfill
« on: January 07, 2023, 05:56:05 pm »
Hi all
Bit of a school boy error but I have overfilled my 2005 gti.
I’ve attached an image to show where the oil level is now and one with the cleaned dip stick for reference
Can I get away with the oil at this level?
  • -Receive: 691
Re: Engine oil overfill
« Reply #1 on: January 07, 2023, 07:05:59 pm »
I’ve done that before and that’s over 1 litre overfilled. If you have an oil extractor, suck some out, otherwise just let the engine burn it off.
Offline odav
« Reply #2 on: January 07, 2023, 08:47:42 pm »
Thanks for the quick reply.  :smiley:
I don’t have an extractor and happy to let the engine burn the oil off. Just wanted to make sure I’m not doing any damage to the engine by taking that approach?
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: January 08, 2023, 04:30:14 pm »
You could let some out of the sump plug, would be messy though.
Offline OllieVRS
  • -Given: 17
« Reply #4 on: January 08, 2023, 07:19:09 pm »
I vote for this option, if it's easy enough for you to do.
There's a possibility (although unlikely) that low oil pressure could be caused from over-filling the oil, causing engine damage.
If a little flashing scary red oil light appears on your dash, then it's definitely time to correct the oil level.
'06 Skoda Octavia vRS TFSI
Offline odav
« Reply #5 on: January 16, 2023, 02:03:39 pm »
Thanks for all the relies on this. I ended up taking it to a garage I’ve used for many years and they drained enough oil to bring the level back down to ‘max’
No charge either  :smiley:  :happy2:
