Author Topic: Rear camber and toe issue  (Read 1300 times)
Offline Slowdriver934
  • Newbie
« on: April 20, 2023, 02:21:57 pm »
I recently had my mk5 gti rear suspension arms replaced as the previous owner was from Scotland was rusted to sh*t was a big and expensive job to get done. I just went to go get it aligned and they couldnt get it lower that -2 on both sides when they torqued it it would just go to -4 then -2 again. Had it checked and no damage to subframe or any other parts or bushes. Anyone have any idea of how to get these straight?
« Last Edit: April 20, 2023, 02:33:07 pm by Slowdriver934 »
Offline breeze
Re: Rear camber and toe issue
« Reply #1 on: April 20, 2023, 04:35:41 pm »
You might find that the bush for the main trailing arm (if that is what it is called) is worn out on both sides.
Similar happened to me recently. I had to replace the big arms as well. There was just too much flex in the rubber because it was old and soft.
Offline mjmallia
  • -Receive: 58
« Reply #2 on: April 21, 2023, 07:53:58 am »
The rear trailing arms go over looked a lot, due to being covered up and located into the chassis.
My car used to twitch in the rear a lot, and after taking them off the car the bush was shot creating a lot of play. Put a poly bush in and that resolved my issue.
Mike
South Coast
Offline mjmallia
  • -Receive: 58
« Reply #3 on: April 21, 2023, 07:56:32 am »
Here was my old bush and the car passed an MOT prior to this being removed, but suspect it had been worn out for a while.
then poly bushed them
Mike
South Coast
Offline mjmallia
  • -Receive: 58
« Reply #4 on: April 21, 2023, 07:59:24 am »
It hides in here:
Mike
South Coast
  • Newbie
« Reply #5 on: April 21, 2023, 10:48:25 am »
Thanks guys I'll give that a go and put an update on after
