Author Topic: Noises from the rear  (Read 2092 times)
Offline K03MK5
« on: October 12, 2023, 10:40:06 pm »
Starting to hear creaking noises from the rear while coming to a stop driving at slow speeds.  Any suggestions?
Offline GreigC
Re: Noises from the rear
« Reply #1 on: October 12, 2023, 10:51:10 pm »
I have my car booked in next week for the same noises as yourself. The rear control arm bushes are tired on my car so we suspect this is the issue. So I’m getting the rear control arm bushes replaced, ARB bushes and drop links at the same time. Hope this helps.
Offline TheBALDpuma
« Reply #2 on: October 20, 2023, 07:36:02 am »
Mine is making the same noises too, was going to replace the ARB bushes and the drop links - hasn't looked at the control arms so will look at those too now!!
Offline GreigC
« Reply #3 on: October 20, 2023, 08:17:06 am »
Just had my rear control arms replaced with new bushes already fitted, ARB bushes and drop links and its still doing it! :doh: I’ll need to look further into it…
« Last Edit: October 20, 2023, 08:19:08 am by GreigC »
Offline TheBALDpuma
« Reply #4 on: October 20, 2023, 09:04:15 am »
GreigC - Do you mind if I ask you home much that lot cost?  I have been planning to do the work myself but my time keeps getting taken up with other jobs, so thinking I might book it in.
I know it hasn;t fixed your problem so it might not fix mine, but the state of the ARB bushes in particular they need doing anyway!
  • -Receive: 691
« Reply #5 on: October 20, 2023, 10:13:43 pm »
It's probably the trailing arm bushes. The ones that sit in the recessed cup.
Offline TheBALDpuma
« Reply #6 on: October 23, 2023, 12:58:14 pm »
What's the general consensus on ECP bits like Starline and Febi for droplinks and bushes?  Is there much differene between OEM in terms of quality anbd price?
Edit to add...
Just been on the phone to VW and the droplinks are basically £100 inc Vat for a pair (£50 for starline at ECP) and the D-bushes for the ARB are about £30 (£6 Febi from ECP) not including the bracket and the bolts - is it likely I'll need to replace those too?  Is OEM worth it in this case? it's a lot extra!
« Last Edit: October 23, 2023, 02:34:46 pm by TheBALDpuma »
Offline terrier
  • My Ride: GTI now gone
« Reply #7 on: October 23, 2023, 04:11:18 pm »
Edit to add...
Powerflex bushes and Lemforder links :happy2:
Offline GVK
  • -Receive: 70
    • GVKmotorsport
« Reply #8 on: October 23, 2023, 08:05:40 pm »
Fitted Starline ARB links from ECP a year ago on the MOT and the drivers side is already worn out and knocking.
Offline TheBALDpuma
« Reply #9 on: October 23, 2023, 08:09:56 pm »
Well I have bought Febi as I was too impatient to wait for a reply haha.  Will have to see how they go, some pretty mixed reviews on the net but they aren't expensive so if they don't last then I'll upgrade next time
