Author Topic: Coolant gauge goes to 90 and stays there.  (Read 1481 times)
Offline Wastedspark
« on: March 31, 2024, 05:43:11 pm »
Evening all,
‘06 mk5 GTI
I’ve noticed lately my temp gauge gets to 90c and stays there’s,
Did some testing earlier today with OBD11,
Output test, both fans run.
Warmed the car up to 84c then drops to 70c, by the time I looked under the bonnet I could see the fans running, and I wasn’t getting a % output on OBD11.
I tried this a few time heating to 84 drop to 70, then the last time it dropped to 55c checked under the bonnet and both fans were running, so I’m happy it’s working but, I can see temps changing on my phone but all the time the gauge still says 90c.
The gauge works correctly as it warms up but just stays at 90c
My coolant bottle is full too.
Any ideas?
Offline Sebas_theFish
Re: Coolant gauge goes to 90 and stays there.
« Reply #1 on: April 01, 2024, 01:14:45 am »
It's supposed to stay there unless there's an issue.
Offline Wastedspark
« Reply #2 on: April 01, 2024, 08:04:30 am »
No it should move to indicate the actual engine temp as it has been doing for the last 10 years,
Moving between 70-90 as the fans come on is normal, the issue is it’s not going back down. Now I’ve proved the fans are working my concern is if I were to overheat would the gauge go past 90 or not.
Offline ZoliWorks
  • -Receive: 24
« Reply #3 on: April 01, 2024, 12:23:08 pm »
VW temp gauge has a flat spot and displays 90c for anything between 70c and 105c. If it drops below 60 on VCDS and the gauge itself is still not dropping, it might be a faulty temp sensor, even if it's not throwing any errors.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Wastedspark
« Reply #4 on: April 01, 2024, 12:29:12 pm »
Thanks, that’s a large amount of latency for temp control but it does stop the gauge from chattering,
I’m leaning towards the temp senders being the issue if it’s not causing a problem I’ll  replace them next cam belt change.
Offline Clarky
« Reply #5 on: April 02, 2024, 01:31:40 pm »
I was waiting for the "April Fools!" ...didn't happen. Have driven loads over the years plus other VAG cars, thats just how their stats seem to roll. Top dead centre and its all fine. Only ones i have ever experienced moving have been fubar
Offline OllieVRS
  • -Given: 17
« Reply #6 on: April 02, 2024, 02:37:40 pm »
Haha this post does seem like an April fools, for any MK5 GTI owners on here, especially this part:
Moving between 70-90 as the fans come on is normal...
Still could be an April fools joke who knows  :grin:
'06 Skoda Octavia vRS TFSI
