Author Topic: GTI cam adjuster/phaser wear - ALL DONE ✔️  (Read 19211 times)
Offline RBS
  • -Receive: 49
Re: Cam adjuster/phaser wear
« Reply #15 on: October 20, 2024, 06:24:56 pm »
INA is an official VW suplier so you’re good on parts there :happy2:
Offline mjmallia
  • -Receive: 60
« Reply #16 on: October 24, 2024, 02:51:24 pm »
Taking a day off and attacking this job tomorrow.
Found another workshop manual stating the 20Nm plus 45 degrees, so doing this as it is the most common result I have found.  I will then check the torque after
Mike
South Coast
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,134365.msg1165175.html#msg1165175
« Reply #17 on: October 25, 2024, 02:14:01 pm »
That’s the correct torque spec
Offline mjmallia
  • -Receive: 60
« Reply #18 on: October 25, 2024, 02:22:34 pm »
Well I started this today at 8am and finished about 6 hours later.
Not that bad a job if your methodical about it. Took the usual apart once at TDC to get to the cam adjuster. Marked the camshaft also to see any movement
 I attacked the bolt with the cordless Impact and the socket was getting quite warm with no give on the bolt.... so let it cool before I then used a breaker bar and it then gave way and eased off without issue THANK GOD!!!  The theory of the impact was to help break the metal bond, and it appears to have worked for me.
The welded up cam tool kit off Ebay worked a treat
The cam adjuster had wear as expected and it was a little difficult to jig the casing off, but replaced the rings anyway.  It also looks like it had additional damage from dragging a broken ring part (near the outside ring groove)  Glad I changed it.
Tensioners were the same make as expected, even the casting marks are the same with 7 years difference
Put the new INA parts on and the old chain had a little play when the chain was placed on its side (this job was done 7 years ago when I got the car)
Marked it up using the Decimal Tenths tip and fitted it all.
Cleaned up the mating surfaces for the new gaskets
Turned the engine over by hand a couple of times and all was fine........then put it all back together and warmed up the car.
The cam case with the rings glided on with ease
Before the phaser was -3 degrees on a hot engine
And now it's 0 degrees also on a hot engine, so very happy.
No more minor rattle I was tuning into between 1k and 2k revs, so very, very happy
« Last Edit: November 04, 2024, 03:21:03 pm by mjmallia »
Mike
South Coast
Offline lazy
« Reply #19 on: October 25, 2024, 06:09:31 pm »
Congratulations on a hard job well done. :happy2:
Offline mjmallia
  • -Receive: 60
Re: Cam adjuster/phaser wear - ALL DONE ✔️
« Reply #20 on: October 25, 2024, 06:23:54 pm »
Thanks  :happy2:
Mike
South Coast
Offline ZoliWorks
« Reply #21 on: October 25, 2024, 09:03:49 pm »
Congrats!
Mine was +3 to +6 before and now, after, it sits at 0 to -3. I could be wrong but if I remember correctly, my bank 1 spec is 28 while actual is 27.5 most of the time at idle
« Last Edit: October 25, 2024, 10:09:20 pm by ZoliWorks »
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Milltek Catless Resonated Exhaust | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline mjmallia
  • -Receive: 60
« Reply #22 on: October 25, 2024, 09:22:08 pm »
They are 28 on the later TFSI's, but the AXX variant is 24
I am curious about the 2nd data box on group 91 being 56.1%
I suspect it is because there is some load from the aircon. I might check it with it off tomorrow
« Last Edit: October 25, 2024, 09:25:17 pm by mjmallia »
Mike
South Coast
Offline mjmallia
  • -Receive: 60
« Reply #23 on: October 25, 2024, 09:48:07 pm »
It appears to be the duty cycle of the N205. Wondering if it is faulty, but there are no error codes and car runs great.
Mike
South Coast
Offline ZoliWorks
« Reply #24 on: October 25, 2024, 10:11:23 pm »
Aight that's great, I was getting worried. I'll go for some midnight snacks in a bit and take a VVT pic for you. I've replaced my VVT control module/valve thingy. I dont remember exactly but I think it was between 37% and 57%
Offline mjmallia
  • -Receive: 60
« Reply #25 on: October 25, 2024, 10:31:38 pm »
The VVT solenoid valve may be stuck or dirty, as all the info i see on them at idle is upto 7ish %.
I will have to take it out and give it a clean
Mike
South Coast
Offline ZoliWorks
« Reply #26 on: October 25, 2024, 10:41:09 pm »
Honestly at that point just replace it. I've got mine, I think INA, for 20 bucks. It's been a long time so dont quote me on the log numbers just yet xd
Offline mjmallia
  • -Receive: 60
« Reply #27 on: October 27, 2024, 09:23:40 pm »
Just to close this off for people.
It seems that the duty cycle (group 91, block 2) controls the oil flow in the solenoid to keep the timing in check
less than 50% retards timing
more than 50% advances
50% locks the timing without adjustment
So a good result for me here.
Mike
South Coast
Offline Numero9
Re: GTI cam adjuster/phaser wear - ALL DONE ✔️
« Reply #28 on: November 12, 2024, 01:23:58 pm »
how did you get the tools via TPS, I need to tackle the same job but the TPS near me won't sell to none trade anymore!
Offline mjmallia
  • -Receive: 60
« Reply #29 on: November 12, 2024, 01:29:05 pm »
I used to work at the VW HQ and know all the guys (some are good friends) at the local TPS where I live, so that is my access to them these days
Mike
South Coast
