Author Topic: Big Brake setup fitted!  (Read 7695 times)
Offline geordie56
« on: April 10, 2010, 08:31:23 pm »
I know its for Golfs but the chassis is the same if anyone wanted a setup like this! I have a golf aswell thats why im registered, just thought id post some pics. All this setup was supplied by DaveB who as a lot of people  know is really good with brakes and had done another amazing job here!
« Last Edit: April 10, 2010, 08:42:37 pm by geordie56 »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Big Brake setup fitted!
« Reply #1 on: April 10, 2010, 08:49:14 pm »
i'm not sure but aren't your front AP disc turning the wrong way??? seeme the cooling ducts go the wrong way  :confused:
Very nice setup though, looks ace  :drool:
Over the top mod list ;o)
Offline geordie56
« Reply #2 on: April 10, 2010, 09:03:10 pm »
Hmm  now you have got me thinking, is anyone else in agreement with the last comment or does it not make much difference? Cheers.
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: April 10, 2010, 09:11:11 pm »
i agree with the above. I thought the vanes should scoop the air up as they rotate forwards.  it would make quite a difference oin cooling on them.
they also look absolutely ace.  what size are the discs?? and what pads are you running on them?
Offline geordie56
« Reply #4 on: April 10, 2010, 09:14:37 pm »
I have just found this and this would state that with my discs they are the correct orientation am i right? The discs are a straight vane and therefore the vane is correct running towards the back of the car from the inside of the disc to the outside.
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
Straight
Pillar vane (comprised of many small posts)
Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
The Discs are 350mm and im using mintex pads but also have a set of racing pads.
« Last Edit: April 10, 2010, 09:25:45 pm by geordie56 »
  • -Given: 243
  • -Receive: 155
« Reply #5 on: April 10, 2010, 09:28:33 pm »
you are right as i wrote the above the centrifugal force was teasing me, i have always thought the opposite but of course the cooling air goes from center out.  :congrats:
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: April 10, 2010, 09:30:23 pm »
i also bow to the superior knowledge :ashamed:
Offline QD MBE
  • -Receive: 102
« Reply #7 on: April 11, 2010, 07:28:58 am »
x2
Offline fuscobal
« Reply #8 on: April 11, 2010, 12:19:57 pm »
Very good job. How much for the fronts ? (calipers/carriers, discs, pads, brakelines... ). Also, I suppose they won't fit under the OEM 17" Denver GTI wheels but what about the OEM 18" Detroits ?
Mk5 GTI 6MT - Revo stage 3
Offline geordie56
« Reply #9 on: April 11, 2010, 09:43:15 pm »
If you speak to DaveB who i dealt with, a really good guy and knows his stuff im sure he could sort you out and as for fitting under 18" im not sure could be tight it also depends on the offset.  I cant give you a price as i got fronts and rears at the same time so it was all one price.
Offline vwrascal
« Reply #10 on: April 11, 2010, 09:49:34 pm »
 :drool:  stopping porn! candy calipers FTW   :congrats:
Offline Vick N
« Reply #11 on: April 11, 2010, 10:11:43 pm »
I want those brakes but more so the wheels! What are they?  :love:
Offline fuscobal
« Reply #12 on: April 12, 2010, 07:54:23 am »
Yeah, I know Dave, I've purchased some stuff from him. What discs did u used for the rear R32s ? Are they just drilled or 2-piece lightened as well ?
PS : What was the price for the entire setup then cause I can guess how much is the rear only since I've bought one too :) !
« Reply #13 on: April 12, 2010, 02:28:15 pm »
i think i saw these brakes before they were posted! they look the shizz mate!!!!
I just wish i had a suitable car to put them on! ;)
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #14 on: April 12, 2010, 02:34:07 pm »
Would look the shizz on the S3 :wink:
