All Things Mk5 > Sat Nav and Car Audio
Factory Fit Arm Rest CD Changer
<< < (2/8) > >>
Moschops:
--- Quote from: cameluk on April 24, 2010, 12:02:13 pm ---If you are changing the standard arm rest to the version for the cd changer/mdi version and have the rear vents working then you will need to change the air channel pipe that runs underneath to clear the bottom of the cd changer
1K0 864 255  £14.50
The bottom part in this picture
Its the biggest pain in the rear to change over  :fighting: as it appears to be too big for the space available
--- End quote ---
Mr Camel,
Does this part have a letter after it please? Just my local parts dept have one in stock but not sure if its the right one without jumping in the car and popping up there to see it, anyway they have asked does it have a letter on the end of the part number?
cameluk:
--- Quote from: Moschops on April 26, 2010, 11:04:46 am ---
Mr Camel,
--- End quote ---
You want the version WITHOUT the letter on the end, the version with C on the end of it is for the non cd changer version
Moschops:
--- Quote from: cameluk on April 26, 2010, 01:44:20 pm ---
Mr Camel,
--- End quote ---
--- End quote ---
Thanks Camel....the bit have has the letter on the end... :sad1:
animal:
What is required to add the Aux-In port? I have the CD changer cable - presumably some additional wiring is required?
I have the hole in the front of my arm rest, rather than stick the blanking panel in I may as well add the Aux-In facility, but other than the 3.5mm Aux-In socket shown above, what else do I need?
I take it that the Aux-In and the CD changer are able to work together given that you can only get the CD changer version of the arm rest with the Aux-In cut out in the front (as far as I know anyway)?
Moschops:
Hello,
My set up has everything connected (overkill if you like :signLOL:)
VW must do a cable for the CD Changer and the Aux socket, the ones I bought to do the job are the wrong ones as they will only connect the CD Changer up and not the AUX as well. At present I don't the correct part number.
So Mr Forum (SteveP) took my cables (looms), CD changer and the MDI kit and has made a loom to connect them all, which after todays fitment I'm pleased to say they all work.
Do you have the CD changer already? and the correct housing ?
If not you'll need to swap the housing, get the correct cable, Aux socket and also the correct air duct to run though the arm rest.
HTH.
Any other questions post em up... :happy2:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
