Author Topic: Air con not working ;-(  (Read 10505 times)
Offline Drapoon
Re: Air con not working ;-(
« Reply #15 on: April 27, 2010, 01:06:47 pm »
Rang vw - basically as my car is 9 days out of Warranty I will have to pay £69.99 for them to investigate the problem & also it wont be covered under warranty :sad1:
Offline scotta
  • Edition 30
« Reply #16 on: April 27, 2010, 01:32:46 pm »
I would call VW customer services direct see what they say.
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #17 on: April 27, 2010, 02:44:09 pm »
What Scotta said, and then at least see if they will give you the 69.99 off the final bill if they do find out whats wrong, and you get them to fix it.  Although that sounds ridiculous amount, unless they are going to do a full leak test/recharge!   :surprised:
Offline Drapoon
« Reply #18 on: April 28, 2010, 09:36:42 am »
Small update - I located one of the shraeder valves on the piepwork to the air con & pushed it in with a key to see how much gas I had - hardly anything!
So getting the system re-gassed tomorrow before I do anything too drastic.
I hope I haven't mashed the clutch using it with hardly any gas....?
I located the compressor but could not quite see the label to identify which unit I have, will keep u posted ;-)
cheers all
Martin
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #19 on: April 28, 2010, 09:38:56 am »
Hope that fixes it, the biggest problem with low gas, and with not using it regularly (all Aircon) is that the gas carries around the lubrication for the seals so hopefully it will re-pressurise and you can cool down again  :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #20 on: April 28, 2010, 10:04:35 am »
cheers all
Martin
You don't have to see the label on the pump; look at the side of the rimdriven whell that faces away from the pump, if all black you have xezel, if it has a non painted spring then Sanden  :happy2: As per my pictures in the linked tread previously  :wink:
Over the top mod list ;o)
