Author Topic: ETKA number for S3 caliper/hub bolts front and rear sorted :o)  (Read 2910 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Hi,
Can someone help me with ETKA number for S3 caliper/hub bolts front and rear??
Cheers,
Jake
« Last Edit: May 05, 2010, 07:22:33 pm by danishmkvgti »
Over the top mod list ;o)
Re: ETKA number for S3 caliper/hub bolts front and rear
« Reply #1 on: May 05, 2010, 06:19:02 pm »
 :mad: [not mad but just calling]
Calling stokeballoon, the inside trader!
Calling 'DaveB-for-Brakes' guru!
Calling SteveP, guardian of the EKTA database!
  • -Given: 243
  • -Receive: 155
« Reply #2 on: May 05, 2010, 06:23:25 pm »
i know, but they are most likely getting prepped for the ring  :signLOL:
just measured the iron and alloy hubs today, 18mm difference  :surprised:
Offline QD MBE
  • -Receive: 102
« Reply #3 on: May 05, 2010, 07:03:47 pm »
PM'd
Offline ashley
« Reply #4 on: May 05, 2010, 07:33:57 pm »
PM'd
I8mm difference in which area? so guessing there not a straight swap afterall.....  :sad1:
Offline QD MBE
  • -Receive: 102
Re: ETKA number for S3 caliper/hub bolts front and rear sorted :o)
« Reply #5 on: May 05, 2010, 07:38:00 pm »
PM'd
It is a good swap, however the brake caliper carrier mounts are thicker, due to being alloy.  It is the only difference, hence you also need to look at the caliper carriers if you have a Big Brake kit (BBK).
