Author Topic: S3/R32 Splash Guards - How to adapt for GTI?  (Read 10700 times)
« on: June 07, 2010, 06:23:03 pm »
For rear brakes but I guess the answer would apply to fronts as well.
THX to JPC for selling me the splash/stone guards and packaging them to look like pizza's with a bite taken out! And sexy black bubble wrap - Never seen it in black before.
IIRC there's a 'trick' necessary to adapt them to fit the Mk5 GTI when with S3 rear brakes. Can someone please confirm and, if so, try to describe what the adaptation is?
I can photograph and post pics of my guards if it helps.
Thanks  :drinking:
Offline QD MBE
  • -Receive: 102
Re: S3/R32 Splash Guards - How to adapt for GTI?
« Reply #1 on: June 07, 2010, 06:41:59 pm »
RR,
Are they for the rears?  If so I don't think they will fit.  Send me your Chassis number and I take a butchers on Etka and find which guards will fit.
« Reply #2 on: June 07, 2010, 07:28:49 pm »
I'd best PM my chassis #.
The guards Jay sold me are 1K0 615 612 S and 611 S and dated 30/07.
Offline QD MBE
  • -Receive: 102
« Reply #3 on: June 07, 2010, 07:47:35 pm »
My Etka chassis number converter is playing up.  I will try again later.
D
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #4 on: June 07, 2010, 08:55:52 pm »
RR, you need S3 alloy hubs for them to fit, stokey is your man for these parts. if you buy them you need all the bolts to fit them as well, 7 pieces methinks  :wink:  :drinking:
fronts fits on your existing heavy iron hubs, but will of course fit the light and steering lightened S3 alloy front hubs  :P
« Last Edit: June 07, 2010, 08:58:02 pm by danishmkvgti »
Over the top mod list ;o)
« Reply #5 on: June 07, 2010, 09:04:13 pm »
Cheers, Jake  :happy2:
I have S3 brakes on the rear and AP Racing BBK on the front (already with splash guards, I think!).
Offline alex_chung
« Reply #6 on: June 07, 2010, 09:15:59 pm »
Oh crap does that mean I need to get S3 Alloy Hubs to get my R32 rears fitted with the splash guards? I am sure I saw somewhere that someone had modded the splash guards to fit?
Alex
  • -Given: 243
  • -Receive: 155
« Reply #7 on: June 07, 2010, 09:17:10 pm »
you talk about brakes mate, i talk about hubs, not the same,  :smiley:
  • -Given: 243
  • -Receive: 155
« Reply #8 on: June 07, 2010, 09:18:34 pm »
Alex
absolute no need to panic, just bend the standard gti splash guards gently away from you and the are fine  :happy2:
Offline alex_chung
« Reply #9 on: June 07, 2010, 09:23:52 pm »
Alex
Kewl kewl, that is what I want to hear  :happy2:
Any pics on how? Or is it fairly obvious?
Alex
Offline QD MBE
  • -Receive: 102
« Reply #10 on: June 07, 2010, 09:29:43 pm »
Fairly obvious Alex.  Just offer the disc up and push the guard away slightly around the circumference, then when you get the disc mounted, check it will rotate without catching the guard.
Ideally it should be close enough, but not touching not to allow stones and shyte to get caught between the disc and guard (ask TC about the noise that makes!)
HTH
ps the disc is the first thing you fit so it makes it easy.
« Last Edit: June 07, 2010, 09:31:16 pm by stokeballoon »
« Reply #11 on: June 07, 2010, 09:31:06 pm »
Alex
....Except that I no longer have my GTI splash guards :sad1:. So I guess I'll be offering these from Jay for sale!
  • -Given: 243
  • -Receive: 155
« Reply #12 on: June 07, 2010, 09:34:06 pm »
Alex
just get stokey to find the alloy rear hubs to you  :grin:
s
  t
    e
      e
        p
          s
            l
             o
               p
                 e
                     a
                       h
                         e
                           a
                             d
                                 :jumping:  :drinking:
Offline QD MBE
  • -Receive: 102
« Reply #13 on: June 07, 2010, 09:36:32 pm »
Alex
When I first fitted my S3 rears ages ago, I tried the s3 guards that came with them, and could only get one out of the 3 bolts to fit.  To get the GTI ones off I had to cut a piece out, due to the guard being fitted to the hub, and then the wheel bearing housing and wheel mounting flange being fitted.
The guard is whole, and not like a letter 'C' like the fronts are.  So RR you will have cut a segment out of the new ones to get them to fit.  (in fact the s3 variants are similar in shape, but profiled differently, and with differently centred holes).
Offline gillm
« Reply #14 on: June 07, 2010, 09:40:07 pm »
s3 rear and r32 rear guards dont fit as they are 4wd hubs fairl obivous tbh . gti ones still fit with tweeking as said millions of times i guess vwr binned yours for the same reason they left my suspension loose !
west tuned gt28 @ 340hp
