Author Topic: Which Antenna Adaptor Needed For RNS-510 Installation?  (Read 5039 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Which Antenna Adaptor Needed For RNS-510 Installation?
« Reply #1 on: September 04, 2010, 07:02:44 pm »
Which radio are you replacing and what age is the car?
Offline R32 mad
« Reply #2 on: September 04, 2010, 07:07:11 pm »
I'm replacing a RCD-500 and my golf is a 2007 / 57 reg  MY08.  And the RNS-510 is a version C .
« Last Edit: September 04, 2010, 07:10:45 pm by R32 mad »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: September 04, 2010, 07:08:29 pm »
Then you need the double adapter  :happy2:
Offline R32 mad
« Reply #4 on: September 04, 2010, 07:11:20 pm »
ok Thank you very much.
Offline R32 mad
« Reply #5 on: September 05, 2010, 02:48:11 pm »
Would I definitely need to order this part or does the original wiring not fit straight onto the back of the unit?
Offline Poppa Dom
« Reply #6 on: September 05, 2010, 02:52:36 pm »
IIRC my RNS510 was a different connector and I definitely needed this  :happy2:
Offline R32 mad
« Reply #7 on: September 05, 2010, 03:21:57 pm »
And this is regardless if its an early 2004 mk5 golf or a 2009 mk5 golf?
Offline winrya
« Reply #8 on: September 05, 2010, 09:05:33 pm »
You dont need the adapter, there are 2 aerials in plastic connectors, take one of them out of the connecter and plug it into rns-510 and then the other will fit in its plastic connector.  Or, you can take them both out.  if you google it, you will find most people use this method!
Offline R32 mad
« Reply #9 on: September 10, 2010, 10:15:31 am »
Is this the other option?
I'm interested to know if you plug the biege and white connectors into the white connector leads coming from the dash?
It's an antenna adaptor from VW. Part no. 7L6051551   VW quoting £28
« Last Edit: September 10, 2010, 01:42:05 pm by R32 mad »
