Author Topic: vRSAlex's Octavia vRS Estate - New Mods On  (Read 353187 times)
Re: vRSAlex's Octavia vRS Estate - New Mods On
« Reply #630 on: May 18, 2014, 08:51:55 am »
 :party: :party:  can't wait till she's built!
Offline Pikey Motorsports
« Reply #631 on: May 18, 2014, 11:25:58 am »
Alex you got a rfd kit on the shelf?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline Bignod00
  • Ginsters are sh*tE!!
« Reply #632 on: May 18, 2014, 04:15:13 pm »
+1! :popcornsoda: :pomppomp:
Offline vRSAlex
  • -Receive: 253
« Reply #633 on: May 18, 2014, 09:02:07 pm »
Not in stock. Just grab the CTS ones from PSi.
Follow AKS tuning on Facebook
« Reply #634 on: May 21, 2014, 08:50:18 pm »
Tryed them the other day mate they where out
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #635 on: May 22, 2014, 12:58:04 am »
 :popcornsoda:
Offline Alex.Parris
« Reply #636 on: May 22, 2014, 01:01:23 pm »
Will be immense once done.
At least part of my old thing lives on  :pomppomp:
Leon Cupra REVO Stage 2 | Full Milltek Exhaust | AMD Induction Kit | Forge DV | Eibach Sportlines
Offline vRSAlex
  • -Receive: 253
« Reply #637 on: May 28, 2014, 10:09:30 pm »
Balanced and matched Mahle Motorsport pistons and DM rifle drilled rods. Need to gap the rings then they can get built up.
Block now bored to 83mm and honed to perfection. Block has had a very slight skim too.  Will get painted up to look better than new.
Valves are on their way over, so the head can get finished.  Won't be long until the engine is together.
Body shop work is coming along nicely.  Not giving away what's being done until it's finished.
Offline Jussa
  • Bicester
« Reply #638 on: May 28, 2014, 10:50:07 pm »
Great progress - looking forward to a spin in the beast  :happy2:
« Reply #639 on: May 28, 2014, 11:46:08 pm »
Bored to 83mm so is that a slight increase in capacity too?
Rifle drilled? Whats that mean?
« Last Edit: May 28, 2014, 11:47:46 pm by richwig83 »
Offline mdmay
  • -Given: 38
« Reply #640 on: May 29, 2014, 01:10:47 am »
rifle drilling is a process that produces deep, straight holes in a variety of materials. A rifle drill tool differs from a conventional twist drill by its unique head geometry; a standard rifle drill has a single effective cutting edge. Guide pads burnish the hole while drilling, allowing the hole to maintain straightness. The result of this burnishing activity is a very round hole with a precision diameter.
 when drilling with a normal twist drill you will get drill wander and a slightly ovaal hole unless reemed. the gun/rifle drilling process is much more accurate but slower band more expensive but overall much better.
 another process that can be used is using slip collars after drilling which are pullled through a drilled hole to prevent star cracking around a hole.
i previously worked in london undergrounds machine shops producing points and crossings and all these process were used
Regards,
Mike
« Reply #641 on: May 29, 2014, 02:36:44 am »
Always better to have the bores honed when rebuilding instead of just dropping pistons in
And rifle drilled rods allow more oil to cool the bearings.. If you look at the picture of the rods you will see the hole drilled
« Last Edit: May 29, 2014, 02:38:57 am by Pikey Motorsports »
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline bigmig95
  • -Receive: 50
« Reply #642 on: May 29, 2014, 10:52:21 am »
Alex is this setup fixed or floating pin (The bearing material on the little end gives the game away  :ashamed:) are you aware of any DLC coating on the gudgeon pins themselves.  :happy2:
As alex has described rifle drilling is pretty good  :happy2:  I've seen spark eroded holes on the 2.0 TFsi sparked from either end to meet in the middle with a nice stress raiser step halfway up.  Needless to say the rods decided they weren't happy and made a right mess.  :grin:
« Last Edit: May 30, 2014, 08:09:20 am by bigmig95 »
Offline RedDejavu
« Reply #643 on: May 29, 2014, 12:27:21 pm »
Wonderful car mate!  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #644 on: June 06, 2014, 08:22:22 pm »
New wheels have sooooooooooooooooooooooooooo much clearance to the brakes.  Very very happy!
Engine is coming along when I get the odd 20 seconds here and there.  Polished the crank, fitted the APR main studs and fitted the crank.  Ring gapping next then the pistons and rods will go in.
